Question about Panasonic AG-1330 VHS VCR
AG-1330 the tape won't eject and during playback it looks like the tracking is off. The LED shows F04 or F06 as the errors. What do they mean?
  • 2,130 Answers
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Another possibility is that the tape is caught aroung the spindle guides that pull the tape around the video head. If the tape is caught in the spindles, this will affect playback performance. The heads could be dirty too. Another possibility for poor playback is a slipping idler wheel. The idler wheel is a rubber tire that pivits between the tape sending and pickup reels. It's a key part during playback, fast forward & rewind. The idler tire can also be treated with a re-grip solution or be replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor.
Posted on Jan 15, 2008
  • SHARCNET-USA
    SHARCNET-USA Jan 15, 2008
    I dont know specifically what the error codes you mentioned mean, but there are sensors in the VCR that detect a problem is present and will either display a code or flash an LED.
  • SHARCNET-USA
    Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. You can rotate the pully and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved.
Panasonic NV HD630 is showing error f06 when the eject button is pressed. The tape cassette seems to be locked in and does not rise. I have removed the top. The tape is withdrawn back to the cassette....
You have a K-Deck mechanism. F06 means the mechanism locks after unload. The cause of this is the load motor or the carriage alignment.
If you enter "Panasonic K-Deck" into google you should find service information and a guide to getting the tape out - all free!
Oct 13, 2010 | Panasonic NV-HD680 VCR
Panasonic VCR NV-HD642 - F04 Error
You sound like you have a K Deck Model. If this is the case F04 means that the mechanism locks during unloading.
The apparent cause of this is the Load Motor timing.
Aug 08, 2009 | Panasonic Televison & Video
F01 error on playback or recording - Panasonic NV-DX100
Panasonic JVC Description
F01 No Take-up reel rotation
F02 E03 No Supply reel rotation
F03 E02 Mechanism has not unloaded to the eject position
F04 E01 Mechanism has not fully loaded to the stop position
F05 E04 Rotation of video head has stalled or to fast
E06 Tape drive motor is not rotating or stalled
F31 Data transmission error
F51 Focus motor is not functioning, No focus
F52 Zoom motor is not functioning, No Zoom
U10 Dew sensor has detected condensation or failed
U11 Video heads have been detected as dirty or failed
Matti Knuutila mattik1999@yahoo.com
Jul 11, 2009 | Panasonic Video Cameras
Panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
Apr 29, 2009 | Panasonic AG-DV2000 Mini DV VCR
VCR Tape Stuck
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Jan 05, 2008 | Panasonic AG-1330 VHS VCR
Video tape stuck
Hope ya fix it!
Is there lp playback?
no - only sp tapes. if you try an lp tape, it plays for about 2 seconds, then the deck ejects it.
Nov 28, 2007 | Panasonic AG-DV2500 DV/Mini DV VCR
Mosaic picture during playback
either use a manufacturer recommended head cleaning tape or have a tech give it a good hand cleaning. Panasonic head cleaning tapes work well.
Nov 14, 2007 | Panasonic AG-DVX100A Mini DV Digital...
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic AG-1330 VHS VCR Logo
250 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
