Question about Water Heaters
My electronic gate is making a loud noise when operating and seems to be struggling when openning and closing. It is timber and opens in and out not sliding. I think it may need clog replacement. How do I do that please? Eirena
  • 1 more comment
  • eirena_m Nov 18, 2009
    HI
    In answer to your question, I don't know. How do I determine if it is electronic,pneumatic or hydrolic? I thought it was electric. It has 'majic button' automation and last time it was serviced, the drive cog on the easyglider motor was replaced. That was about 2-3 years ago..
    Where do I go from here please?
    Eirena
    How do I find out which one it is.
  • eirena_m Nov 20, 2009
    Hi
    The clogs are in the motor assembly. The gate is mounted on an arm which is driven by the motor. I could have given you the make and model in the first place instead of asking if the gate is hydrolic etc. Oh and yes timber means wood.
    As my 7 day free access is now about to expire and I still have not been instructed on how to change the cogs I will have to go elsewhere for an answer.
    I think it would be better is you asked all the info you need in the first email e.g. make and model, rather than backwards and forwards with emails until the 7 day free access expires.
  • 3,600 Answers
The Gate must be adjusted and squared up before you replace anything, next lublrate the gears especially if it's cold in your area. when looking at the gears if the center wiggles back and forth you know the gears center pin is worn out, if yhr gear teeth don't mesh 90 percent of the way then the gears are worn out.
Posted on Nov 20, 2009
  • 1,498 Answers
Hi Eirena,
The remedy depends on what is making the noise. You would need to identify exactly where the noise is coming from.
When you say 'It is timber', do you mean it is wood?
Also, I'm not sure I understand what you mean by 'clog replacement'.
Since it opens in and out, it could be the hinges, In this case just oiling them could do the trick. Same with the servo mounts.
If it turns out to be the servo itself, I'm going to need a make and model number.
Best regards
Mike
Posted on Nov 18, 2009
  • Justin Case
    Justin Case Nov 19, 2009
    Check the control box (usually on or near the post the gate is mounted on), the motor (mounted on the same post and the gate) or the remote for company name and/or model number.
    Chances are it's electric. Hydraulic would be overkill unless the gate was excessively heavy.
  • 15,935 Answers
Is this an electric, pneumatic or hydraulically operated system??
Posted on Nov 16, 2009
I hear a knocking noise behind the wall when I use the hot water. What could it be and how do I get rid of it?
I had something similar, but I would call the noise more like 'ticking'. The problem was that hot water would heat up the plumbing vent piping (plastic) for that bathroom and it would expand and then contract (after shutting hot water off). As the pipe 'grew' it would make noise sliding through the opening in the ceiling header. It seems that builders had stuffed loose fiberglass around the pipe there that served to let the pipe move freely. The fiberglass had fallen out and the pipe was rubbing against the wood and making noise. Stuffing new fiberglass in the opening around the pipe fixed it.
Oct 29, 2014 | Water Heaters
Why does the toilet make so much noise filling FluidMaster 703A5B
Just replace the flush valve with another one.
Flush the water line by opening valve before attaching new flush valve
Aug 07, 2014 | Fluidmaster 507C White Flush Valve
I have a hot water boiler with 3 zone valves and 2 circulation pumps. I see no relays wired to pumps. Pumps run constantly
Sounds like a lot of unknowns from your article. Here are some basic checks
- if they are the honeywell zone valves and you try to open them and get resistance than 9/10 times the t-stat is not calling for heat and the valve should be closed
-if stat is calling and wants heat zone valve lever should be free of resistance when moving it
- 15-20 psi is a little high but could be normal based on the size of your place and the temperature you are reading these pressures at
-with the pumps always running seems to me that the pumps are hard wired to a constant electrical source, if you want optimal control install a taco zone controller
May 21, 2017 | Water Heaters
Loud vibrating sound coming from hot water heater. Had gas company change meter and regulator. At first was losing hot water while in the shower. Went through check list after it coded out at #12, all...
Can't address other issues, but WATER pressure should be 40 to 80(I'd say 70)lbs. tester at home D for $10-15. Goes on hose Bibb outside, or at washing machine cold valve.
Mar 18, 2017 | Rinnai Water Heaters
When the pump is running, if I turn on the cold water faucet the check valve opens and closes rapidly making a loud knocking sound. This problem only developed after four years of trouble-free operation.
Clean out check valve with CLR calcium-lime-rust and see if functionality is restored.
Problem can also be caused by air bubble inside the line, caught at the check valve. Dissemble and reassemble parts. Install air vent.
Another option is to install direct return line with in-line check valve and air vent.
Parts can also be ordered.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Jul 24, 2011 | Laing Thermotech Autocirc Undersink...
We also installed the water filter GXWH40L. We never had any issues and have gone through probably five replacement filters. We recently changed the filter and have horrible water pressure. We changed it...
If you have GATE valves on either side of the filter make sure the have opened all the way. They can become unscrewed and although it seems like it opened they gate can be almost closed. If the outside spigots are on hard water try the pressure there.
Water filters for pre-filter housings come in different micron ratings. They can be anywhere from .5 micron on up to 100 micron. The smaller the number the finer particulates it filters out and the faster it will plug up. Generally most filters used for residential households are 5 micron to 50 micron rating and the most common used are 10,30 or 50 micron. Try a 30 or 50 micron filter to see if it helps. But remember the larger the micron rating the more particulates pass through.
If there is a lot of sediment coming the well and building up in the bottom of the pre-filtet housing you may want to flush the well or consider having the well inspected by a well company. You could have a pinhole in the drop pipe that is letting sand in.
Run one of the outside spigots in to a clean white bucket, let the pump cycle several times and inspect for sediment in bucket, let it settle for about 20 minutes to see if excess sediment is coming from well. Have your water tested to see if the water chemistry has changed also.
RJ
Dec 07, 2010 | General Electric GE SmartWater Household...
I have water up to house but nothing inside and i...
Check the valve that you shut off on the inside of house for water.
A gate valve can come appart the stem will unscrew form the gate and will look like it's open, but the gate remain's in the closed position. If this is the case ,you will have to cut water off and remove stem to valve to access valve or disconect it from the line.
You have a blockage somewhere not allowing water to flow, Try to go over anything that you may have shut off. Maybe something is in the lines causing blockage.
May 21, 2010 | Water Heaters
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Dec 08, 2009 | Amtrol Water Heaters
Takagi TK-JR vibrating noise
Remove your hydronic pump and replace the flexible impeller coupling that couples the impeller blades to the pump motor. make sure you don't do this on a sat or, sunday (i hate house calls then) and, be sure you have a new pump housing gasket before you start the job. Also check the unit for loose pipe brackets
May 20, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Blinking red light,
It seams alot of people have this same problem All must get ahold of manufacturer and report this it must be there pump's thank you for useing fixya
Jan 14, 2009 | Noritz 6.3 Gallon Residential Tankless...
Water Heaters Logo
49 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
