Question about Garden
I have a knocking sound coming from the rear of my 1990 nissan primera, mostly occurs when going over bumps. Help please...?
    Sergeant:
  • 399 Answers
Hi try bouncing it by hand to locate the noise it could be your shocks
Posted on Nov 16, 2009
    Problem Solver:
  • 12 Answers
Check your rear staberlizer arm bushes
Posted on Nov 19, 2009
What does it mean when the battery and abs light come on in a 1991 Nissan primera?
ABS is voltage sensitive, so will not work when alternator is not charging. Possible causes are fan belt, alternator or wiring connections.ABS will reset once alternator is repaired and car driven a short distance.
May 30, 2011 | 1990 Nissan Pulsar
I have a knocking sound coming up through the centre of the dashboard. I have been told by Nissan Service that it could be a broken weld. Of what? It is most noticeable when turning the wheel even...
IS this noise in the steering column? Please check to see if this is resonating from the column, if it is you may have a bearing issue in the steering shaft that IS IN FACT A SAFTEY ISSUE. Please be safe. If a dealer has told you that you may have a broken weld and its NOt an issue, GO TO ANOTHER dealer. If the weld was not important, Nissan would not have spent Millions of dollars placing it there.
Dec 07, 2010 | 2005 Nissan Altima
I have 2004 Sentra. There is a loud knocking in the front end when driving over bumps. Struts were replaced last year, so I am wondering if the noise might be a strut, en engine mount, or sway bar mount....
start by looking at all the bushings on the front end, leave the car in gear and rock it to check engine movement, use a prybar to check for movement in the bushings, you'll find it
May 23, 2010 | 2004 Nissan Sentra
On my Nissan Primera sve 2002 the display screen does not work
The most likely cause of most problems electrics on that model is the poor earth connection on the rear light cluster. There is a simple fix which you can find on the nissan primera owners club website. www.npoc.co.uk. The fix is easy to do and involves putting another earth from the rear cluster to the bodywork where there is an existing bolt. It solved my issues.
Sep 06, 2009 | Nissan 200SX Cars & Trucks
How would I install an upper suspension arm to
nissan primera in the US is called an Infiniti G20. the grinding or knocking if its coming from the front, is gonna be the tension rod bushings are warn out. get new tension rods for real cheap. thats all i can help with, suspension is my thing, motor is not.
Jul 16, 2009 | 1995 Nissan 200SX
I've got a 1994/L nissan primera 1600 16v Twin cam and for some reason it wont start off the key but if you bump start it it runs
ok,first off make sure your battery isnt dead,,,if thats ok then id suspect the starter motor,,does it sound like a clicking noise when you start,,its either one or the other anyway,,,if it starts off the key when you use jumper cables then you need a new batt,,hope that helps
Apr 24, 2009 | 1990 Mazda MX-6
Audi A4 Quattro (2004) bumping/knocking from manual transmission
HI,IT SOUNDS TO ME LIKE THE TORSION DIFFERENTIAL ON THE GEARBOX IS CAUSING THIS,PLEASE TRY THIS,DRIVE THE VEHICLE TO A OPEN AREA,YOU MUST PUT IT IN 2ND GEAR AND DRIVE IN A CIRCLE ONE WAY ABOUT 10-15 TIMES,AND THE SAME THING CHANGING DIRECTION,THE REASON I SAY THIS IS TO LOOSEN UP THE TORSION GEARS,PLEASE LET ME KNOW,ANDY.
Feb 25, 2009 | 2002 Audi A4
Primera 1990 P10 makes loud noise from belt when starting
i recently experienced the same issue. it can be your tensioner pulley or your water pump see the belts are connected to the pulleys and sometimes get worn out and need to be replaced. especially on a older car see a mecanic
Jan 31, 2009 | Nissan Pulsar Cars & Trucks
Knock in the rear end
I say take it back to the dealership!
Jun 20, 2008 | 2008 Hyundai Accent
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
