Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Me 60" sony tv has green color and the problem is not the setting
    Problem Solver:
  • 6 Answers
Check your bulb
Posted on Nov 16, 2009
TV has RED and GREEN colors distorting the color output of the TV. Can not simply adjust color and hue. Red and Green still remains controlling and dominant. How do I fix this?
If it does this on all inputs then it is the tv itself. You can try different sources and cables to see if the problem is not the tv. If the problem is the tv I would suggest having the tv repaired. It looks like a nice unit so it would probably be worth fixing. I would find a reputable local shop to take it to.
May 25, 2015 | Sony Bravia KDL60EX720 60-inch 3D LED TV
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Screen problems on a sony 60" widescreen tv
if some area of the screen even with the color set at zero is green go to an unused video input and look---this model is well known for red green or blue discoloration of what appears to to be the screen but is actually the optical light engine which projects the picture into a mirror which projects it on the screen.
attached is a typical light engine, note the round lens to the left , that is the optical unit that projects the picture into the mirror at the rear of the set which puts it on the screen----the engine is the most expensive part in the set so, .........
Dec 08, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
How do I get the yellow/green color toned down on our Sony KDS-60A2000 TV?
If the screen has a yellow green color to the whole or most of the screen in this model it may be a defective optical light engine.
A photo posted here of the issue or elsewhere might tell me.
Mar 21, 2012 | Sony KDS-60A2000 60" HDTV
I have a 46" magnavox projection screen tv that has the red, blue, green colors on the left side of the screen when first turned on. After a few minutes of being on, the screen resumes to normal colors. ...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Philips 60PP9352 60" Rear Projection...
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
No blue color, green replaced blue, white is yellow/green
If the set is hooked up using Component cables (red, green, blue), then check to make sure the cables are hooked up correctly, and not defective (change them out). If the color problem remains, then the problem may be in the Optics block of the television (which is not unheard of in this unit).
If the menu of the TV displays blotchy discoloration, and the discoloring is the same for every input on the tv (stationary), then it is the Optics, and the optics need to be changed. It is not the easiest job in the world, and the block itself is quite expensive, although the unit my be under an extended warranty from Sony. Contact them directly to see if you can get any help (cost or service-wise). Hope this helps...
Dec 29, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
TV background in green and most of the people have green tint
http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
Dec 17, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Color of picture
turn off the color completely and see it the picture is black and white or has a shade of green,if so your gayscale needs to be adjusted
Sep 09, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
