Question about Odyssey Steel 2 Ball Srt Putter
Drivers seat is tilting back and forth, a bar underneth is broken
  • 105 Answers
It can be a spring that came loose from its spot under the seat look to where it should be or the seat could be back to far and it depends on how old it is if it has just broke down make sure nothing it in the way and the lever id not stuck hope this was helpful:)
Posted on Nov 16, 2009
2009 Acadia power seat tilt not working
If all other functions of the seat are working then you're more than likely either looking at a bad switch, wiring to it or the motor is bad, if the tilt uses the same motor as the up and down or back and forth, then it's probably the switch.
Jul 17, 2016 | 2009 GMC Acadia
Seat adjuster
Most are not fixable, made from stamped metal. It is better to purchase another seat from the junkyards. Call around first. Also, it does not have to be the same make and model as most seat are very similar.
Nov 22, 2013 | Cars & Trucks
Passenger seat will not slide forward
there will be bars underneath the seat that are supposed to go across to unlock both sides so that the seat can move forward and back, try having someone pull the lever and see if you can see from behind the bar that moves and figure out what it corresponds to on the opposite side. you should be able to move it by hand, release the lock and set the seat where you want it, as for a permanent fix, most seats are not difficult to remove, typically four bolts, although some take specialty tools like large torx bits, and i would imagine the bar is replaceable
Jan 27, 2013 | Cars & Trucks
2003 C240 driver's seat won't adjust
CONTROL PANEL UNIT IS BAD
Sep 17, 2012 | Cars & Trucks
Pasenger seat
Mark, try moving the seat back itself, rocking it back and forth whilst operating the tilt lever, you may need an extra hand
Aug 05, 2012 | Peugeot 307 Cars & Trucks
I have a 2006 Kia Sadona, electric front seats. The passenger seat will tilt back slowly but will not tilt forward. How do I return the seat to the upright position? Can the electric switch still work...
yes, usual you will find coins or something lodged in the treaded bar on the seat motor, if not water damage can corrode the bar, check the bar as it goes in and out. ( rate me )
Aug 29, 2010 | 2006 Kia Sedona
The driver seat on the 1984 mercedes sl wont tilt forward.
hi,better to remove the seat,for proper checking of gearing of motor,alignment of railing of seat,apply grease on railing,careful,seat are heavy,ty
Apr 09, 2009 | 1984 Mercedes-Benz S-Class
Driver seat removal
If you have power seats just look underneath the seat and you can unplug the electrical connectors that go to any of the seat accessories. Then you can remove the seat. Sounds like the left side of the seat frame has broken that supports the seat back.
Mar 16, 2009 | 2006 Ford Focus
Odyssey Steel 2 Ball Srt Putter Logo
53 people viewed this question
Top Odyssey Sport & Outdoor - Others Experts
Are you an Odyssey Sport and Outdoor - Other Expert? Answer questions, earn points and help others
