Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
It says the filter needs to be cleaned; where is it?
  • 66 Answers
Ask for the technician to cleaned it
Posted on Nov 16, 2009
How to clean washable filters?
To clean the washable filters you need few things like a stool, screwdriver, brush for cleaning, vacuum with attachments and running water. Cleaning the air filters regularly will keep you away from different type of allergies which are caused by fungi, molds and bacteria.
Sep 30, 2014 | Water Dispensing & Filtration
Removing the filter model fdl7051
Hello Friend, this is Z. Thank you for allowing me to assist you!
You would need to remove the bucket to locate the filter of your Frigidaire dehumidifier (FDL70S1). Then pull the filter downwards for cleaning. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions and typically the FILTER REST light will illuminate after 250 hours of operation. Hope this helps!
Aug 12, 2014 | Frigidaire Dehumidifiers
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
Mar 14, 2014 | Maytag MMV5208W Microwave Oven
Cleaned my filter out now it will not pump,never had a problem till now
Once shut to clean the propeller needs to be cleaned as it gets clogged. You need to pull out the piece housing the propeller and rinse off or use a thin item to wash out any debris stuck.
Sep 17, 2013 | Tetra FS3060 Power Filter
Clean filter message reset
the filter will need to be cleaned and if the set still shuts down then I would suspect the fan may need to be cleaned and possibly replaced.
Aug 07, 2012 | Panasonic PT-43LC14 43" Rear Projection...
I have cleaned the filters, and i still get the Clean Filter message. It is running fine, but the red letters Clean Filter are still there... any suggestions???
How did you clean the filters? I run mine through the dishwasher by themselves and it works pretty good. The tops and bottoms of the filters near the edges need to be wiped pretty clean.
Jan 02, 2011 | Brookstone Pure-Ion (506840) Air Purifier
Filter needs cleaning as water does not empty
I was unable to locate your filter in your machine but if it would help after you clean the filter you could install an inline filter between the valve and the hose. This is an RV filter it just screws on like the hose.
http://www.flowpur.com/html/rv_filters.html
The FP12GKE shows just how easy it is. Any RV filter will work.
Aug 19, 2009 | Washing Machines
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
How do I clean the filters
Generic problem for all Vacuums
How do I clean the
How do I clean the filters?
Comment by Avonb, posted on Apr 22, 2008 I have a Bagless twin clean, thought I was cleaning the filters but apparently not, the manual is very vague
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the Model # or Brand name, it is a good idea that you can vacuum of the filters, if you have a blower – you can blow off the dirt from the filters, some filters are washable and you can clean them by washing them and letting them dry completely before you re-install the filters. Idea? If you have an old paint brush, that is ideal to clean off HEPA filters or cartridge filters or use a blower to clean off the dirt. You need to be the best judge on how to clean the filters. You can check the company’s website for the brand name such as:
http://www.hoover.com ---- example given
Don – The Vac Man
Apr 22, 2008 | Vacuums
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
