Question about LaCie 300722 DVD±RW Burner
Won't recognize disc-cd or dvd
Everything seems normal lights, disc drawer opens and closes, but the disc doesn't get recognized. It clicks every few seconds and then it ejects the disc. Nothing shows up on my screen. I have tried it on my iMac, and my Powerbook. Any ideas. Brian
  • rockcarver Jan 09, 2008
    Thanks Craig, How do I access get in to clean the lense? Brian
  • rockcarver Jan 10, 2008
    I took the entire unit apart until I could find the laser. It looked clean, I wiped it with ear bud and then reassembled and tested it with a CD for a read, and it had the same problem. So now what, is it junk? I hardly has any hours on it at all, though I bought it a few years ago. Any help would be appreciated. Thanks, Brian
  • 34 Answers
The pick up or in other terms laser is faulty if its not under garrentee start by opening the tray and clip of the tray`s cover open the writer and clean the lense with a ear bud and then test it if no response it gets more technical or its time to replace, i hope these tip help you
:)craig
Posted on Jan 09, 2008
My hp1040lightscribe won't recognize the drive for burning. Help. It keeps telling me to put a blank disc in and when I do, it still doesn't recognize it and won't burn it.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps you
Aug 18, 2011 | HP LightScribe dvd640i (DVD640I)...
Player does not recognize any discs
please do simple process by simply cleaning the lens area with cotton swabs. please don't try to play any disk in try open stage, you may damage your player thanks gizmo
Dec 27, 2007 | Sony CDP-C505 5-Disc CD Changer
The DVD writer doesn't recognize that there is a
Most DVD drives are also CD drives, and it sounds like the DVD part is broken, you need to replace the DVD drive, this is done simply by buying a new one, I recommend Newegg.com ( if your unsure search exactly what you already have) then opening your case (tower) and just unplugging old one and plugging new one in, it really is very doable for even a novice.
Jun 26, 2011 | HP Computers & Internet
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
I have a NEC DVD RW ND-3530a and my windows xp service pack 3 stopped recognizing it. it no longer reads as a drive. The device manager has it listed with a yellow !. I have tried uninstalling and...
Remove the drive from your computer, and temporarily connect it to another desktop computer.
If it still does not work, then it's time to responsibly recycle it, and spend $40 to purchase a new CD/DVD reader/writer.
Dec 10, 2010 | NEC ND-3540A DVD RW Dual Layer Burner
Does not recognize any cds
Insert a CD that has writing on the top, noting which way the lettering is facing. Close the drawer. Wait a few seconds. Open the drawer.
If the lettering still is facing the same way, the disk did not "spin".
So, the motor that spins the disk is dead. Replace the CD/DVD unit.
If the disk does spin, then the laser inside the unit has failed. Replace the CD/DVD unit.
Sep 10, 2009 | Computers & Internet
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Drawer closes by itself
The loading mechanism is off by a tooth or 2. The tray out position switch is not being triggered properly and the tray will reenter the machine. Did this just start happening? It is possible that the sensor switches are defective too. Worse case scenerio is about $5 in parts plus the local labor rate for repair.
Dan
Mar 28, 2008 | Pioneer HTD-520DV System
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
LaCie 300722 DVD±RW Burner Logo
152 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
