Question about ViewSonic CyberVision C704 17" CRT Monitor
TV LCD CYBER VISION 1933AM
THIS TV IS WITH THE KEY CHANNEL + AND CHANNEL - BLOCKED FROM FACTORY.HOW CAN I UNBLOCKED THIS KEYS.YOU CAN ONLY CHANGE THE CHANNELS VIA REMOTE CONTROLLER,BUT USING THE KEYS FROM PANNEL NOT.THANKS !!!
  • 395 Answers
SOURCE: TV screen behave like power is cycled from On-OFF-On when channels, volume or any remote menu button changes.
Do you have CFLs on in the room or adjoining rooms?
Posted on Jan 17, 2008
  • 14 Answers
SOURCE: cant program directtv remote to sony tv
I'm not sure of your model number but those remotes use the NEC codes and the variants on the NEC codes. If that code set is not the databse, you may have to "learn" it on your particular remote.
Good luck
Posted on Jul 13, 2008
  • 29 Answers
SOURCE: Vizio 32 inch -- using remote to change channels.
tyr to dismatle youre remote and you can see the key pad
,clean it by using pencil eraser.coz there are full of carbon inside.
Posted on Jan 20, 2010
  • 8457 Answers
SOURCE: remote rc00136p not working. only up channel and freeze
Take ur extended warrenty get a new remote.The CPU in the remote is dead.
Posted on Feb 16, 2010
SOURCE: Channel changes automatically
my panasonic TC-21S15R tv some time auto channel change and blue screen.
Posted on Apr 21, 2010
Lock key
Channel locked. Refer the user manual for details about to unlock channel.
Jul 01, 2013 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
How to unblock channel vision television
You try menu of your tv and select a channel or auto program and adjust
Feb 03, 2013 | Channel Vision (C0314) (c0314)
Vision quest tv says tv program blocked
How to unblock a renoir vision quest tv when it says program blocked?
Feb 04, 2011 | Element Electronics FLX-1910 19 in. LCD...
"K" in pink background after part installation LCD tv from sharp
When you see the "K," hit channel down and volume down on the tv. Hit the down arrow key once. You should see some the says factory init. Use the channel up and down to select "Factory Init" and hit the right key to change to yes and hit ok. Once it turns green, unplug set for 30 seconds and plug back in.
post back here if I was too vague or if you get confused and I'll write up a more easier one.
May 28, 2010 | Televison & Video
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Child Lock is on and I am second owner of tv with no code
This function will block out the picture and sound of the selected channel or video input.
It can also be used to keep the TV from being viewed for a scheduled time period that you set.
The code to enter the Locks feature is a four digit secret code number. The factory preset code is 0000.
Use the number buttons to select access code.
Use CURSOR G or H to highlight function and then press the SELECT button.
To change the access code number, select Change Access Code. Enter a new four digit key number you prefer.
Select CHANGE ACCESS CODE to change factory preset code (0000) to your preference.
When ENGAGE LOCK is selected, SET CHANNEL LOCK, SET INPUT LOCK, and SET FRONT PANEL LOCK can be set individually.
When SET CHANNEL LOCK is turned on, the picture and sound for the chosen channel will be blocked out.
When SET INPUT LOCK is turned on, the picture and sound for all video inputs and the picture and sound for channels 3, 4 will be
blocked out.
When FRONT PANEL LOCK is turned on, all buttons on the Front Panel will be deactivated, except the Power button.
When TV TIME LOCK is turned on (r TIME LOCK) you can set the BEGIN and END times (CURSOR E) and the TV
cannot be viewed during that time period (Set clock first). Use CURSOR G or H to highlight ONCE (TV will time out one time
only), DAILY (TV will time out every day), WEEKLY - SUN~WEEKLY - MON (TV will time out one time a week) or OFF (to disable
this function).
When MOVIE RATINGS is selected, you can block various types of movies and video tapes based on motion picture ratings. Picturein-
Picture will also be blocked automatically (see page 45).
When TV RATINGS is selected, various types of television programming based on a parental guide ratings will be blocked.
Picture-in-Picture will also be blocked automatically
If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit the menu.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
ViewSonic CyberVision C704 17" CRT Monitor Logo
90 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
