Misaligned copies im working on a copier machine konica 7135 and gives me misaligned copies on lead edge..i already checked the program but still nothing happened. can anyone help me on this matter.thanks
  • an2ny Jan 16, 2008
    both from RADF and Platen Glass..
  • 589 Answers
Please be more specific in the problem:
Are they crooked on the glass, or through the RADF?
Posted on Jan 09, 2008
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error F-35-9 code
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Mar 03, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
When a print job is sent to my Konica Minolta Bizhub c352, it only flashes "data" light, but nothing prints.
Does this happen when you copy. Try different document and program pdf word web page etc. Static IP or DHPC? Recommend static IP for copier/printers
Feb 14, 2014 | Konica Minolta bizhub C250 All-In-One...
F-28-1 curently appears on my screen
F 28-01 High voltage power supply abnormality.
Ihe charging ON/OFF operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging.If there is a paper in copying process when this jam occurs,the machine stops after completion of copied paper ejection.Verify the charge wire,change and the holders.Check the high voltage unit.
F - 28 -02 Toner transfer wire malfunction
F - 28 -03 Toner separation wire.malfunction
Feb 11, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
How do i clean konica 3035 copier roller - where is it located
just with a dry piece of cloth.
or copy 40 white sheets(blanch) at least.
Jul 23, 2010 | Konica Minolta Office Equipment & Supplies
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
May 20, 2010 | Konica Minolta Bizhub c203 Copier
Registration problem konina 7065
timing adjustment, perform the following.
1. Access the 36 mode (power the machine ON while holding down on the 4 and 7 keys.
2. Press [2] Image adjustment.
3. Press [3] Timing adjustment
4. Press [3] Lead edge timing adjustment
5. Press [Copy Screen]
6. Load 11x17 paper into tray 1, make a copy of the pyramid chart, and check the output.
Standard value: 3mm max.
7. If the lead edge original amount is different to the standard value, press the C button while pressing the P button.
8. Enter a value from the numeric keys on the screen, and press (SET) key.
Setting range: 0 (small) to 99 (large)
1 Step = 0.064mm.
9. Repeat steps 5 to 8 until the lead edge original erasure amount becomes the standard value.
10. Press the [PREVIOUS SCREEN) key to return to the Timing Adjustment Menu Screen.
11. Power the machine OFF/ON to exit the 36 mode.
PLEASE NOT THIS IS A LEADEDGE ADJUSTMENT.THE REIGIST ADJUST IS THE SAME STEPS JUST CHOOSE REGISTRATION OPTION ,AND MAKE SURE TO FOLOW PROPER DIRECTION.
Jul 02, 2009 | Sharp AR C250A Color Copier
k24674
jasbo
jasbo
