The problem has been solved on my Go Video recorder player not being able to get content on dvd's but now the problem was corrected by Guru ginko. I do not want any more charges to my card for services thatI will not be needing. Thank you.
    President:
  • 704 Answers
To cancel your subscription to Fixya, please send an email to premium.support@fixya.com along with a copy to lauren@fixya.com and put in the title of the email, that you wish to cancel your account, subscription, etc.
That should get you taken care of. If you have any other charges that you do not authorize, you can always contest the charges through your credit card company as well, provided they are not charges you approved when you requested an expert to provide you with service or advice to resolve a problem.
Hope you find this Very Helpful and best regards!
Posted on Nov 16, 2009
Sony VX420 combo what region should I set it
If you wish to get some details; check the site linked here. Pull up older posts.
Sep 09, 2016 | Sony Televison & Video
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Mar 24, 2011 | Panasonic DMR-ES10 DVD Recorder
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
No audio for mmdv2 O/H dvd player
Hello! If I understand you correctly, you have no audio at all; Both on radio and dvd player but video functions normally? Check fuse #14 (20A) located in the Integrated Power Module...It is located in the engine compartment...
Guru...........Saailer
Apr 07, 2010 | Audiovox MMDV2 Car Video Player
How do I transfer recordings off my lg hdd RH1999H to my laptop? Is it even possible?
The generic answer is yes you can. You will need to use a software app like Pinnacle Studio V10.5 onwards (currently V14) or similar II think that Roxio have a product too) that will take raw video format from the DVD Player / recorder and convert it to MPEG2 files that you can then convert to any other format. You can then edit them and put them back tot he DVD Player / Recorder in the correct format for viewing on TV. This will also allow you to burn customised discs with TV content etc.
Oct 18, 2009 | LG RH1999H DVD Recorder/HDD Recorder
My DVD player is playing in back and white. How
If you haven't already, use a good DVD lens cleaner in the unit to ensure the problem is not just a dirty lens. Next (if this did not correct the problem) ensure the output of the DVD player matches the input of the TV.....dvd out-ch3, tv on ch3....dvd out-video, tv on video....etc. Let me know what you find
Apr 07, 2009 | Philips Magnavox MWR10D6 DVD Recorder
NOT ABLE TO RECORD
Key thing to remember when recording anything is the following: 1.  Color to color on the back of the machine      Video -yellow      Sound - White and red 2. Make sure your source is output and the recorder is input. 3. Be sure that it is original content that you are trying to record ie make sure you are recording from a VHS that is "Kids do Beauty and the Beast for 5th grade play" and not "Disney Beauty and The Beast"
Legal Copyright Info This information is intended for help with original work.  It is not intended for misue or copy of copyright materials.  Most DVD Recorders will not record protected content, but for those that do not provide copyright protection I assume no liability and will not be responsible for damages or legal action resulting from the misues of this information.
Jan 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Cannot finalize dvd-r
Have solved the finalized problem by simply looking on the Canon website and read that you have to plug the camera into the wall to do it! If only they simply put this in the manual!!! Goodluck!
Mar 01, 2008 | Canon DC95 DVD Camcorder
Problems with Daewoo DH-6111D HDD/ DVD recorder
I checked in the instruction manual and found out that I had not "finalised: the DVDs that I had recorded. So I reckon that this will solve my problem.
Feb 21, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
