Question about GE Profile JTP18 Electric Single Oven
Ge profile oven is in lock mode not able to turn it on , it says HOLD UNLOCK BUTTON FOR THREE SECONDS BUT THERE IS NO SUCH BUTTON, WHAT BUTTON SHOULD I HOLD DOWn?
    Problem Solver:
  • 14 Answers
Hold the "lock" button for three seconds.
This is the way mine works, yours is probably the same way.
Holding the "lock" button for three seconds changes it from locked to unlocked and ALSO from locked to unlocked.
Posted on Nov 16, 2009
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    How to " unlock" the
    your oven is on self cleaning mode, and it locks it
    Jan 10, 2011 | Whirlpool Ovens
    After self-clean cycle oven door won't unlock
    your lach might have given out on self clean. change it
    Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
    GE True Temp Profile Oven, Locked Door Light stuck on
    there should be some type of button that the door hits to turn it on and off
    Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
    GE: E Profile Single Electric Oven Model: JSP40W0WJWW
    First press and hold the cancel/off button for 10 seconds.
    If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
    The 2 thermal switches are located on top of the oven behind the control panel.
    Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
    Slef cleaning oven Frigidaire electri clean oven lock will not un
    set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
    then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
    then turn off the temperature knob.
    Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
    Ge profile oven loc
    hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
    Yay!
    Island2
    Apr 22, 2008 | GE Profile JTP18 Electric Single Oven
    Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
    most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
    you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
    Print Range - “LOCKED DOOR” flashes in the display
    If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
    Motorized Switch
      1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
      2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
      3. While you hold the door jamb switch in this position, complete the following steps.
      4. Press the Clean pad, wait 10 seconds.
      5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
      6. Wait 10 seconds for the display to clear.
      7. The door should unlock and there should not be a need for service.
    Manual Switch
      1. Press the Clean pad.
      2. Close the door.
      3. Slide the latch to lock the door.
      4. Hit the cancel button immediately.
      5. Unlock the door.
    If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
    Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
    GE Profile JTP18 Electric Single Oven Logo
    977 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Are you a GE Oven Expert? Answer questions, earn points and help others
