Question about Microsoft Windows Media Player
I have a probelm with my windows media 11 not recognizing my Apple I pod and my free Agent External hard drive. I want to put music on them but am not able to do so . Help Thanks Jojo
    New Friend:
You can not your apple i pod not recognize with media player you have to use the quick player to recognize your apple i pod.
Posted on Nov 16, 2009
SOURCE:
My computer recognizes this hard drive, but windows media player does not
With Windows Media Player open, hit the F3 key. You get an Add To Library window providing you with an option to sync folders from other sources...like an external hard drive.
Select the option to add My folders and those of others I can access. Then you click the Add button.
Now you can see the Add Folder window. Search for the folder where you stored your music on the external hard drive and select it. Then click the OK button.
This will add the selected folder on the external hard drive to the list of synced folders. Once the Add Folder window disappears, Windows Media Player starts syncing the music and adding it to it's library.
Aug 14, 2015 | SmartDisk FireLite Computers & Internet
Ipod Touch HELP!! My hard drive crashed. How can i take the music from my Ipod Touch and put them onto my new hard drive? I really dont want to lose all my songs and pictures. HELP!!
load itunes
under synch tell itunes not to delete pod it then should copy all on the pod to new AUTHERIZED COMPUTER so make sure you loged into itunes store.
http://support.apple.com/
please do click the 4 little thumbs
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 12, 2010 | Apple iPod touch
I have the western digital media player and it won't read my hard drive
Segate free agent External hard drive not recognizing as a drive
Although in device manager mass storage device is taken as drive for that.
one pop-up is coming "your usb could perform better in usb 2.0
operating system server 2003.
the same hard drive is working fine with windows XP system,but not working with server.
Jan 12, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
I have a 1 terra bit external hard drive . I edited music from a pc to my external hard drive using cd's & lps. I've been having problems with putting my music library in my new laptop computer. One...
Your installed music library in your external hard drive might not be supported by your media center on your new laptop, try to convert the files where the software are supported by your media player. try convert Master software, you can download it free then convert your files
Nov 01, 2009 | Seagate Free Agent Go Small 12 GB USB...
No disk. how to get one. not get in i-pod
There is absolutely no need for a disk with your ipod. Head over to apple's website and download a copy of itunes.
http://www.apple.com/itunes/
It's a free download, free software. Itunes will instantly recognize your ipod and take you through the steps of setting it up and putting music on it.
Mar 23, 2009 | Apple iPod nano
Xbox 360 Not Playing Music Through External Hard Drive
In windows media player 11, click on the small down arrow below library and select media sharing. Check the box for share my media then turn on you console. I dialog box will pop up asking you to approve file sharing. You can then customize your options for that device. If the dialog box dose not pop up you have a firewall problem. For the Iomega Media Drive, you have to use the software that came with it. Open the program click on configure, select the folders icon, and look next to your media folders and make sure DLNA is on otherwise your console cannot access those folders.
Feb 22, 2009 | Microsoft Xbox 360 Console
My GPX ML648B is not being recognized on any computer any longer
• The USB mode uses a file transfer class called the MSC (Mass Storage Class). This was developed as a way for files to be transferred onto an external drive such as a flash drive or an external hard drive.
• In this mode, your mp3 player will look and function like an external hard drive in that it will appear in My Computer as a separate drive. This transfer class is not very specific to the transfer of media files so the MTP (Media Transfer Protocol) was introduced.
• The difference with media files, specifically music files, is that they demand much more management.
• Downloading services can require special licensing and a limit on the number of playbacks a music file can have.
• The acquisition, restoration, updating, and backing up of these licenses as well as compatibility issues with file type and compression ratio within these digital music players demanded a more user-friendly and functional approach to file transfers.
• For this reason, you will need to have Windows Media Player 10 or 11 available on your computer to utilize MTP.
• Those with Windows Media Player 9 on their Windows 98 SE, Windows Millennium Edition, and Windows 2000 operating system will need to update using our Download Center.
• We recommend the use of MTP over MSC (the USB mode on your player) because it is more specific to the transfer of music files. To change this setting, press the power button on your device once it’s connected to the computer until the USB icon disappears.
Jan 08, 2009 | GPX ML648B MP3 Player
Ipod music is gone, but still says it has stuff on it
If you do this through itunes, it should be okay. The trouble is everytime you want to update your ipod, you will need to connect it with itunes and itunes will need to have your existing library that you created for you ipod to perform a quick and troublefree update.
If you are going to get an external harddrive you will need to re-direct where itunes is saving your music and video files. Because itunes will be using your internal harddrive for the system files (that is where windows is), it will automatically save the music to your internal drive. I suggest reloding an updated version of itunes from http://www.apple.com/itunes/ here and when asked where to install it, redirect it from C:programfiles.......to your external harddrive. This way the itunes music folder will be on your external harddrive.
Hope this helps
Nov 02, 2008 | Apple iPod MA446LL/A MP3 Player
I pod touch
ipods are only designed for itunes so windows shouldn't recognise media player, any way, the new software for ipod touches is greater, meaning your computer/windows media player wont recognise it, only itunes will.
Cheers
Oct 18, 2008 | Apple iPod touch
Microsoft Windows Media Player Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
