Question about GE (PSS26MSRSS) Side by Side Refrigerator
How to remove freezer door inner panel to access
Need to thaw water line in freezer door.
  • 78 Answers
Some model you need to replace complete freezer door
Posted on Nov 16, 2009
Model #GSH25JSTCSS---Not getting any water from the water dispenser but still have ice coming out---What's the problem?
I have this same model and problem. The water line may be frozen inside the freezer door. (the line enters at the bottom hinge area of the freezer door)
Shut the unit off and leave the freezer door open ( you will need to remove your stuff you want to save first)
Next disconnect the line coming out of the Freezer door near the bottom hinge (should be a quick disconnect coupler, you will need to remove the front air grill assy to allow access to the line/coupler) and lay the line out on the floor.
After thawing the water should run out the line leaving a small puddle on the floor. Reconnect the line, plug the unit back in and test your dispenser.
Although this method restored my water dispenser to working condition, other possible causes for this include the line freezing up in the refridgerator section, bad water valve, bad relay on the motherboard, that triggers the water valve, bad motherboard. Hope this helps.
Sep 26, 2010 | GE Refrigerators
Water is draining and freezing from the freezer and leaks onto the floor
This is an easy fix! First either remove the back access panel or remove the interior freezer access cover. You can reach the drainline from either side. What has happened is your evaporator drain line is clogged. You will need to use a blowdryer to thaw the ice blocking the drain line. The drain line is located at the bottom of the freezers interior back wall. All you will need is a long screwdriver/clotheshanger. Once you have thawed the line stick your screwdriver/clotheshanger and unrestrict the line. I hope I helped you.
Aug 31, 2010 | Refrigerators
Water collects under veggie drawers constantly and leaks out when opened
You probably have a clogged drain in the freezer. The easiest fix would be to remove all food and let the unit thaw for 24 hrs with the doors open.
The other option would be removing the freezer panel and taking a turkey baster with hot water and running it down the drain line until it thaws.
Jan 22, 2010 | Refrigerators
No water from door. I've taken the water line loose from the siloniod water will flow when activated. but will not come out at the door.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then , the water tank inside the refrig section , behind the crispers , is frozen . If the door line is frozen , pt # WR49X10173 , is a dispensor heater kit , with instruction , to keep the door line thawed .
Nov 11, 2009 | Hotpoint HSS25GFP Side by Side...
I need a left front door/window schematic on line for a 99 Dodge Durango. I need to see how to put it together.
Front Door
  1. Remove the door trim panel.
  2. Remove the water dam.
  3. Remove the inner and outer door belt weatherstrips.
  4. Lower the window to the full down position and align the glass regulator arm with the access holes in the inner door panel.
  5. Remove the front glass run channel.
  6. Remove the nuts attaching the glass channel to regulator arm.
  7. Separate the glass and lift it up and out.
  8. Disengage the power window motor wire connector from the door harness, if equipped.
  9. Loosen the bolts in slotted holes attaching regulator to door inner panel.
  10. Remove the bolts attaching window regulator to inner door panel.
  11. Remove the regulator through the access hole in the inner door panel.
  12. Installation is the reverse of removal. Tighten the nuts attaching the glass to the lift plate to 7 ft. lbs. (9 Nm).
Power window regulator mounting—Dakota, Durango
Window regulator removal—Dakota, Durango
Posting more on next post for door panel removal and installation.
Oct 26, 2009 | 1999 Dodge Durango
Can't get water at the dispenser on a GE sxs
GSS25QMFC I beleive is manufactured by GE. The line could definitely be frozen. 99% of refrigerators you cannot get into the doors. They are glued together and filled with spray in insulation. There is no easy way to do it. You can try a hair dryer or just let the fridge sit for 24 hours turned off with the doors open. Another place to check for a freeze up is in the rear of the refrig section. Most refrigerators run the line in the refrigerator to chill the water and if your refrig section gets too cold they can freeze in there. Most of the time refrigerators have a disconnect in the water line at the bottom corner of the freezer door where it goes through the hinge. You might have to yank off the lower grill to see it, but you can sometimes disconnect it there and let water run out. Good Luck
Sep 11, 2009 | Refrigerators
Water dispenser doesn't work on ge hotpoint freezer
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
Apr 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram refrigerator is leaking water on the floor
At some point the freezer got too cold and the drain froze (it is a poor design with a loop in the bottom). Once this freezes it will not thaw for a long time.
Here is what I did:
  • Remove all items from freezer and let it completely thaw
  • Pull unit away from wall to access rear
  • Cut loop off drain line where it hangs in drain pan
  • Place a bare copper wire (#12 will work) through the drain line and wrap it loosely around the heating coil above drain pan
  • Enjoy
Did this 6 months ago and have not had problem since
Mar 15, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Water leaking from bottom of refrigerator
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Dec 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Everything works but no water
Try turning down the freezer a little.
You can 'thaw' the water line in the door by hanging some towels in the freezer with the door open. Should thaw in a couple hours. At least this way you don't need to empty the freezer.
Dec 08, 2008 | Hotpoint HSS25GFP Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
392 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
