Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Water coming out into sink from overflow spout
  • 66 Answers
Put some seal on the pvc
Posted on Nov 16, 2009
4 Suggested Answers
  • 209 Answers
SOURCE: water escapes on top of sink.
check all your pipes under your sink to the outside grate for blockages, water does come out at some force, the pump would be faulty if it didn't, if its just volume of water, locate the outlet into another pipe further down the drain away from the sink, hope i have helped if so rate me please
Posted on Sep 16, 2007
  • 1314 Answers
SOURCE: Dishwasher drains into sink
im going to try to help but cant quite understand what your talking about is this a portable or built in washer just reply it will e mail me
Posted on Jan 01, 2008
lenwest
  • 150 Answers
SOURCE: water spout on the side continually brings in water
You have a bad water check valve.
Posted on Feb 16, 2009
How do I get rid of the soap suds coming out of my new bathroom sink overflow (the hole at the front of the sink)?
Your sink drain is partially clogged below the overflow drain so suds laden water is backing part way up that tube discharging suds out the overflow opening.If you have a push-pull built in stopper that's probably holding up a clog just below. Clear the clog, soap suds act like they should.
Nov 05, 2014 | Cars & Trucks
Water coming out of overflow
Try getting a coolant tester & making sure that you coolant/water mix is right. Also make sure that you're using the right type of coolant for your vehicle. After that I would check the 2 hoses to make sure neither is plugged. If you have too much water in your mix, it could get hotter and overflow.
Nov 10, 2013 | Kia Sportage Cars & Trucks
Vessel sink
Hi, I presume you mean that the water spout is dripping when the taps are opened, remove the spout (it either unscrews anticlockwise using a tool or pulls up with force) , at the base is a o-ring that needs to be replaced, obtainable from local hardware store.Hope this helps. Don't forget to rate this help.
Oct 14, 2013 | Home
My shower works. water also poors out of a tube beneath the unit
Are you talking about water still coming through the spout at the same time? What overflow pipe are you talking about? If you are talking about the spout, there is a device in the spout that when you pull up on it, the water is diverted to the shower. They have washers in them and it sounds as though the washer is worn out and not making a good seal anymore. You can buy a new generic spout to stop the water or you can take the old one apart and try to find replacement pieces. I have taken one apart and bought a new one to rob the parts off of it before. I hope this is the answer you were looking for. If not, reply to this for clarification and I will try and answer your question more clearly.
Apr 02, 2009 | Home
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Toilet Sink Question
Yes, the water comes directly form the water supply line (not the tank or bowl). It is no different than the water from your faucet.
Aug 27, 2008 | Grohe 20 151 000 Spout Bath Sink
Washing machine
What height is your drain spout? The pipe should be about 3 feet up and then down into the sink or wall standpipe; there should be a water mark behind the machine Your pump pumps the waste water OVER this height. At present your drain pipe must be lying at floor level, which is not correct.
Apr 29, 2008 | Haier XQG50-11 Front Load Washer / Dryer
As background, the dirty water typically goes from the dishwasher to a small tube within a tube, and that goes to the disposal. This ensures that your dishwasher does not back up in the event of a clog.
The problem is likely that the tube that links the thing you see next to your faucet to the disposal is either totally or, more likely, partially blocked.
I recommend taking the entire flex pipe off and inspecting. In my case it was about 80% blocked, so a simple test whereby water was pored down failed to show the issue.
Once I took it apart and gave the tube a plumbing version of an angioplasty all was well.
Dec 31, 2007 | Tappan 18 in. MDR251RE Built-in Dishwasher
Water escapes on top of sink.
Sep 15, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
683 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
