Question about Sony Ericsson W300 Cellular Phone
Handfree connector broken
The connector of my handsfree that goes direct to the cell is broken, I need to have a diagram to repair and weld the cables, there are 5 different colors and I don't know how. Please help me with that.
    Brigadier General:
  • 7,752 Answers
Sorry but you should buy a new one
Posted on Sep 20, 2008
Telefunken mr701 diagram
follow this steps and fix it. God bless you
Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
Jul 11, 2013 | Cell Phones
I have a system that has a turn table cd radio and twin Tape deck but I was not shown where all the connection wiring goes are you able to assist please Cassette deck is FC 261 Tuner FT 261 await any
If you have all the cables it is no secret how they go in. They are either different in length or they will have different connectors on them so you do not make a mistake. Connectors and wires in these things are not too different- If a 5 pin ribbon cable can plug in both connectors and the length of the cable seem right then that is it. I have worked on many of those system and they are not made to last nor be repaired. When you do work on them they usually have multiple problems. That is why it is better to have separate components.
Dec 02, 2012 | Audio Players & Recorders
1995 Geo Tracker 4x4 Heating and cooling cable came loose from the bracket. What is the best way to resecure the cable?
There should be a bracket that has either lost a bolt or has broken. You have 3 choices essentially. Try repairing the bracket, if it's broken, using something like J-B weld available at most parts stores. This will not work too good on Aluminum in most cases. Use a zip tie or wire to secure the cable, which is most likely the best choice, or replace the cable. If your talking about the cable that controls hot or cold settings that is a different story. That has connectors on each end of the cable and if those break off then you have replace the whole cable. Most likely cost about $20.
May 19, 2011 | 1995 Geo Tracker
Handsfree icon on my motorola c118 display,when inserting handsfree its working and i plug out the handsfree the icon is still there.
It's a hardware problem. It might be a connector jack problem. Visit mobile repair center to get it resolved.
May 17, 2011 | Motorola Mobility C118 Cellular Phone
Nokia 6233 showing handsfree mode, without connecting handsfree
your port where z head phone is put is internaly broken
Jun 27, 2010 | Nokia N73 Cellular Phone
I need a wiring diagram for my 1975 iron head harley. Especially from relay to seliniod
I think I can help with the wiring diagram. Contact me directly at wd4ity@bellsouth.net The earliest drawing that I have is for a 1979 model but it can be used.
You starter relay has three connections on it. Usually two large connections and one smaller. One large connection is the hot wire from the main breaker or battery. The other large connection goes to the small connector starter solenoid. The small connector on the starter relay is from the starter button.
On the starter solenoid, the positive battery cable goes to the solenoid long connector. The cable to the starter comes off the shorter large connector. The small connector has the wire from the starter relay.
I hope this helps, if not, drop me a line directly. Good Luck
Feb 08, 2010 | Harley Davidson XLH 1000 Sportster...
I have lost the Red hue in my screen. Any help?
Check the video cable connectors and sockets on your PC and monitor for bent or broken pins. If the cable suffered mechanical stress, a wire inside may got broken or pried lose from the connector internally.
Change the cable for a different one. Connect the Monitor to a different PC or try a different Monitor on your PC to home in on the cause.
If the problem persists and is attributed to the monitor, a fan of the monitor connector soldered to the internal PCB may be lose or broken. This sometimes happens if the connector was pushed in using excess force before.
While a repair shop can fix this easily, I recommend not to try the repair yourself.
Feb 04, 2010 | Princeton Digital VL1918 Monitor
Razr v3 wont charge
Dear jayhawk9977,
Since the AC is fine (tested) then the phone is probably faulty at the Mini-USB connector. Please check if there is play at this point as a broken (damaged that is) connector will not perform any function. (Test is as well with your handsfree if any) If there is no audio at this point 99% is the connector.
Surely the pins that are used are not the same for charging/handsfree but you can get an idea if the problem is bigger than thought initially.
Problematic batteries can also lead to non charging. 3.6-3.7V (+0.3V) is nominal voltage that the battery works. (if you have a multimeter please test it as well)
Many regards
Please rate this solution if you found it useful.
Apr 02, 2008 | Motorola Mobility RAZR V3
Headset problem
Your cellphones speaker isnt working so go to care center and ask them for speaker because its not a software problem its a hardware's problem.. so you have to go repair center for this,,,
Dec 19, 2007 | Sony Ericsson W300 Cellular Phone
Please help me with a diagram for hs-23 plug connections...
http://free-zg.htnet.hr/GoranJurkovic/nokia/
http://cellphones.hackaday.com/2005/08/16/how-to-make-a-nokia-pop-port-to-female-mini-jack-with-volume/
Dec 03, 2007 | Nokia HS-23 Headset
Sony Ericsson W300 Cellular Phone Logo
32 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
