Question about Whirlpool GEW9250 Electric Dryer
NO HEAT DRYER WORKS NORMAL BUT THERE IS NO HEAT
  • Whirlpool Master
  • 3,051 Answers
Hello there;
Normaly this problem is due to a heating element that has failed and needs to be replaced or there is a sensor for the heating element that can go bad too but not as likley as the element.
So i would recommed if you feel that you can do the repair your self
contact you local appliance dealer and tell them you need a heating element for you machine and they will be able to get you the right one.
You will save a lot of money by installing it your self if you have a repairman do this it will cost you around 100 dollars just for the service call and that is not including the 60 dollar part ok?
I hope that this has been very helpful for you
Best regards Michael
Posted on Nov 16, 2009
Dryer is working normal no heat just clod air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 25, 2011 | Dryers
The washer part of the appliance functions normally, however the drying cycle spins normally but does not heat up at all, leading me to think the heating element may have stopped working? If there are any...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 17, 2011 | Dryers
No heat
If everything else seems to work... try checking and resetting the dryer controls to a setting you do not normally use i.e. if you normally set it for hot try the warm or Permanent Press setting. Try something other than the normal setting as this will help indicate if it is the controller or the heating element.
Feb 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My Samsung DV 338AEW, is not heating up, everything seems to be working normal, just no heat.
heatman101
Jan 18, 2011 | Samsung Dryers
It won't heat up. Everything work like normal exc...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | Dryers
No heat in indesit dryer. cycles as normal
Hi
remove back panel and with a mulitmeter check the stats to see if open circuit if so replace and should be back to normal.
regards
Mar 12, 2009 | Dryers
Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
Jan 06, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
