Question about Williams 1403622 Gas Compact Heater
My heater has been off for a year and i want to start it tonight. can utell me how
  • 66 Answers
Check it first before you plug in
Posted on Nov 16, 2009
Kozyworld kwp324
Sounds like water in the line. You could try wrapping the gas line
with insulation, like it was a water pipe.
Can't the gas co. flush the line? OR suggest a fix for a valued customer?
Feb 06, 2014 | Heating & Cooling
How to fill a peugeot 307 with water
this is quite strait forward mix up your coolent and look on the heater hoses for plastic bleed screws and another one on the radiator undo these making sure that they are not blocked adn then fill the cooling system utell all the air has been expeled and only coolent is comming out tighten the screws and fill to correct level
Dec 23, 2013 | NEW QNISSAN10350Z "03-07 CUSTOM NISSAN...
Heater less than 1 year old. Worked fine 3 days ago; tried turning on tonight and got a "E01" in display. Anyone know what that might mean?
E01 is low system voltage. This can be caused by 3 things. Either the incoming power is incorrect, the heater is connected to wrong voltage, or the tranformer is not outputting the correct voltage.
Check voltages going into the heater, if these are all correct, then replace the transformer
Feb 06, 2011 | Pentair Minimax NT Heater
Will not turn on. Unit has been working great until tonight. Was on but now off and will not come on. Unpluged it for an hour but still not working.
This same thing happened to me, and yesterday as well no less. I've had mine for a 3-4 years. I think It had run out of oil, which is weird because I've had a Holmes heater for nearly 10 years and it still has plenty of oil left. If you shake it, can you hear the oil? I went and got another from Target last night (it was the coldest night of the year) and can hear the oil swishing around in it as I set it up. Hope it last longer than another 3-4 years or my next one will be a Holmes.
Jan 22, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Runs for about 15 minutes then shuts off .
I believe the pump setting is 6.0 for the 155 BTU model. I will know more after tonight, we are using a Reddy Heater 155 unit tonight at church. I will look on the side panel and see what the PSI should be for the pump pressure and respond either tonight or tomorrow.
Feb 04, 2009 | Reddy Heater-30-55,000 BTU Variable
Pentair Mini-Max NT Pool Heater does not get very hot
The thermistor is a common failure on this heater. With a setting of 104 and the heater shutting off early, the sensor is bad. If you have a digital display, check the water temp with a thermometer and compare that ot the display. Odds are that they are different. The thermistor plugs into the back of the thermostat board and is a thin whire wire set or thibker yellow wire. The white wire sensors are old and most have fialed by now.
Dec 15, 2008 | Pentair MINIMAX NT TSI IGNITER
Honeywell round mercury thermostat - heat not coming on
If you tip the mercury switch so that it makes contact and the furnace doesn't start, it isn't the t-stat. Check the connections, then start checking the furnace.
In any case, ditch the mercury t-stat (recycle it properly) and get a new programmable one if at all posible. It will pay for itself many times over by turning your heat down in the middle of the night and back up by morning.
Feb 09, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Williams 1403622 Gas Compact Heater Logo
64 people viewed this question
Top Williams Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
