Question about Video Game Consoles & Games
Canon A720IS loose lens
Got some sticky goo on the lens barrel when it was out. While wiping it off I gripped it too hard with the cloth, ''dislodging'' the lens barrel. It's still in place, just loose!!! It wouldn't retract. After ''fiddling'' with it, rotating the lens barrel (and the sliding middle ring), it will now open and close correctly but the rectangular window is at an angle and interferes with the image coming through the lens. The printed markings on the lens are not top and bottom, as they should be) but sort of off center (''zoom'' at 4 o'clock and ''34.8mm'' at 10 o'clock.
Thoughts?!? I'd like to reseat the lens correctly if possible.
  • 105 Answers
The way its made you cannot take it apart and have it to work correctly so if you call the factory and they should help replce it or they should replace it if its in warrenty or you might have to pay a repair fee sorry hope this was helpful:)
Posted on Nov 16, 2009
How to clean sticky pure one elite radio
You'll need lots of patience - a nice day in the garden, a new roll of kitchen wipe and a bottle of methylated spirits. THEN moisten the kitchen wipe with spirit and wipe an area taking care not to over wet and get spirit in radio. the wipe will pick up some of the goo but not much, so..............a new piece of wipe and just keep going. It took me about 2 hours, a quarter bottle of spirit and a whole roll of wipe but is was worth it! Good Luck!
Sep 04, 2014 | Televison & Video
I have a battery door that was cleaned and now is sticky, how do I get rid of the sticky feel? It was cleaned with alcohol.
Its very unusual for alcohol to leave a sticky residue, however try wiping over with vinegar, or even petrol that is for lighters. Put either on a cloth, (don't soak the cloth, just dampen it) and gently wipe, leave to dry. try that.
Jul 06, 2014 | Canon Used EOS A2E 35mm SLR Autofocus...
Hi, i have the Sigma 70-200mm for Canon EF and the manual focus don't work. The HSM works fine and focuses perfect, but if you choose MF, you can't rotate the focus-ring. Many greetings from Germany! Kai
Hi, not sure if you still have this issue. I have just decided to look into it again, as I had a lot of focus problems with my Sigma 70-200mm HSM lens. Since there is no Sigma support here in Beijing, I took a look - and fixed it.
Here is what I did: On the front of the lens barrel is the rubberised focus ring. This can be removed (gently ply it away from the barrel by sticking a flat bit (or plastic letter opener) between the barrel and the rubber grip. It will come not entirely loose, so you need to work your way around the lens. Keep doing that until you moved it about half way forward. At this point two fixing screws become accessible on the barrel below.
In my case, one of the screws had come loose and that blocked the focus ring from turning, as the screw was blocking rotation in the access hole on the barrel.
Hope this helps others. Simple to fix, if you know how.
Nov 26, 2010 | Sigma APO 70-200mm f/2.8 EX DG HSM Lens
My SimpleTech USB 2 .0 External Hard cover got sticky. I kept for quite sometime and when I brought it out, the cover has gotten sticky. How do I clean this?
Turn the device off.
Disconnect any AC adapter.
Dampen a cloth with some dish-washing liquid.
Wipe the surface -- the object is *NOT* to get any liquid INSIDE the enclosure.
So, wipe with that damp cloth, and immediately use a dry cloth to absorb any dampness.
Nov 01, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
My a720is stopped working with the lens still extended. The screen says it is a lens error and that it should be reset. How is this done? The batteries have been replaced. .
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 26, 2010 | Canon PowerShot A720 IS Digital Camera
My ES6000 camcorder has a sticky surface - How can it stop?
Try wiping it with a cloth dampened either with Windex or a 50/50 mix of vinegar and water.
May 10, 2010 | Canon EOS 450D Digital Camera
Rubber grips get sticky after a time instorage. How
Try using some rubbing alcohol on it. Should be able to clean it up.
Apr 12, 2010 | Canon Rebel XT / EOS 350D Digital Camera
The lens cover on my Canon A720is will not close.
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen at this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. The article also gives examples for this type of procedure.
Jan 24, 2010 | Canon PowerShot A720 IS Digital Camera
My Chinon 10x25R binoculars have the same problem.
Simple use soft lint free cloth like old drying up cloth, you need about half a cup of methalayted spirits,can get this from any hardware store.
poke finger into cloth dip into meths proceed to rub sticky coating off binoculars. you will need to keep changing to a new peace of the cloth as soon as it gets coated with the sticky black stuff off binoculars.
keep dipping into meths eventually after say 6 rubs in a particular area you will see and feel a nice hard black plastic, continue all over effected area then finish off with any window cleaner polish until cloth remains clean.STICKY COATING IS NOW GONE IT WAS INFACT A COATING PUT ON THE BINOCULARS TO MAKE THEM NONE SLIP. job done. regards GER8
Jun 09, 2009 | Winchester 10x25 Hunter's Grip Binoculars
Sticky label residue on software CD
try to lossen the residue with a little white spirit, before wiping clean with a damp cloth, always use soft cotton cloths and wipe gently
Nov 26, 2008 | Computers & Internet
Video Game Consoles & Games Logo
21 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
