Question about Panasonic (TH-50PZ700U) Television
Panasonic TV shut off and blinks 5 times and then
Panasonic TV TH-50PX60U shut off and red light blinks 5 times and then repeats????
TVtechmaniac
  • 140 Answers
SOURCE: Panasonic VIERA Th-50PX60U
Replace the SC, SU, and SD boards.
Posted on Aug 24, 2007
  • 133 Answers
SOURCE: Locked Up
i looked at the service manuele, thes is a problem with the 5 volt line, and there are 5 diferant boards that can cause this problem, it is definatily a job for a cervice center, there are 3 pages of testing to get the correct defective part
Posted on Jan 11, 2009
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
dsacco86
  • 1077 Answers
SOURCE: Panasonic Model TH-50PX60U (Screen shutting off..)
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Posted on Jul 05, 2009
Jeff the TV
  • 82 Answers
SOURCE: panasonic th-50px60u power indicator is blinking 10 times
There are two guides, one for 10 blinks at power on:
or, 10 blinks at plug in:
Posted on Jul 25, 2009
Panasonic TC-P55ST30 red light blinks 7 times next to the on/off switch please diagnose, no power
These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link
Dec 06, 2013 | Panasonic TH-50PX60U 50 in. Plasma HDTV
When the Panasonic TH-50PX60U is turned on, the button beside the power switch flashes 10 times, stops and repeats the flashing. The tv will not actually turn on.
10 times red light blinking shows problem with PA board and/or H board, both boards are available in shopjimmy.com for $35 and $45
Replace required board to solve this issue.
Hope this info will help you.
Thanks.
Jan 21, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic th-50px60u power indicator is blinking 10 times
Jul 24, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Jul 04, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
1 yr old panasonic th-50pz700u shut off spontaneously and won't turn back on . red light blinks 8 yimes and repeats
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit).
This has to be replaced, call Panasonic and if you still have warranty you can get it replaced for free.
Jun 03, 2009 | Panasonic (TH-50PZ700U) Television
Locked Up
Jan 11, 2009 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Blinking red light
Same problem with TH-42PZ700U. Took the plug out of the powerstrip and stuck it in the wall outlet and no fix. I will call Panasonic tomorrow. Thinking it might be a heat issue, cause it has been working again after it cools down for 20 mins. Only had this unit since 10/4/07.
Sep 08, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic (TH-50PZ700U) Television Logo
422 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
