Question about Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver
Transfering programmes from sky+ to dvd
When i have transfer programmes from sky+ to dvd recorder, or set up timer to tape from sky+ i get seconds delay on sound as the voices are not in line when they talk. is there a problem with sky+ or is my sony dvd recorder which is three years old.
    Problem Solver:
  • 3 Answers
I think you posted in the wrong location. Sky+ isn't the same thing as the SkyFi.
However, there seems to be lots of issues with recording to DVD and keeping sound in sync with video. I have no idea what the solution is.
Posted on Mar 13, 2008
This morning while trying to copy from vhs to dvd I kept getting an on screen message OTR Pause....record. What is OTR as the tape did not copy this is model DRC832ON
OTR is one-touch recording on most of my VCR/DVD burners where you set the length of time to record from the tv. In my manual it is the Express Record feature. Press the REC button several times to advance the record time by 30 minutes. In your case it might refer to On Timed Record.
Use the COPY button on the front of the unit when the tape you want to record is in the VCR and a blank DVD is in the DVD tray. If you have the A/B Edits set, only the A/B editted sections will copy. (Copy protected tapes and DVDs can't be copied.) (Or the timed transfer described below)
Copying DVDs to VCR tapes can be done in a timed record mode. You can either use Menu > Disc > Copy Disc then press OK or Menu > Timers > Set Transfer and press OK. Then press Info to name the timed event followed by Done and OK, if desired. Press OK to highlight Copy From/To and make sure to select the correct source and destination and press OK. Next set the day and time that you want the transfer to take place (a couple of steps, press OK between them and when done). Then adjust the quality if needed and press OK. Finally highlight Keep Timer and press OK again. Make sure the correct tape and DVD are in place for the timed event.
Depending on what you set the unit for, I'd look for signs of power failures (which mess up most timed record functions). Then I'd double-check the time you set it to transfer and the A/B edits function. (A/B edits lets you grab small clips from an Indexed tape. Either index the tape by playing it and pressing the Insert A/B edit button (on the VCR/DVD, possibly on the remote) or delete A/B edits.)
I hope this helps.
Jul 23, 2010 | RCA DRC8300N DVD Recorder/VCR
Transfer my vhs tapes to dvd
Please check this link
That is the manual for your Instant DVD Recorder try to do the procedure.
Jun 02, 2009 | Pinnacle Dazzle DVD Recorder
New sky digibox fitted. Cannot timer record satellite programmes
I encountered a similar problem when recording and I phoned Sky and they changed my settings to eliminate standby mode for me.
No problem any more.
Mar 21, 2009 | Panasonic Televison & Video
Toshiba d-vr600 record without viewing the whole tape
Unless both units has stated high speed transfer capabilities I think you have to do them one at a time and watch the entire video.
There are some units that are one unit for vhs to dvd. Panasonic is known to have some units but you are going to probably have to hunt for one. It will clearly state that it transferred compressed or highspeed.
Mar 02, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Connect a dvd-vcr recorder to my tb
you will need an external dvd recorder to record vcr tapes to dvd. Sometimes you will have problems with quality when you do it this way. I have transfered vcr tapes to dvd with a transfer device using the computer and got much better results. If you need the name of the transfer device just get back with me and I will get it for you.
Feb 11, 2009 | Sanyo DS27510 27" TV
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Failure in tape to disc transfer
what kind of software are you using. I have had problems with this type of transfer and I had to use a special transfer device. If you want to know about the device write back and I will tell you how I did it.
Jan 07, 2009 | Lite On LVC9006 DVD Player/VCR
I am trying to set the timer record to channel 185, but my unit will only allow me to set to channel 125.
Apr 15, 2008 | Toshiba DR550 DVD Recorder
Transferring vhs tapes to dvd on sanyo DVW 6000
I believe that unit is a DVD player only and deos not record to DVD.
Hope that helps...
Apr 01, 2008 | Sanyo DVW-6000 DVD Player/VCR
Tapes to dvd transfer
I have the same model. DVD is not a recorder.
Sep 13, 2007 | Philips MDV630R DVD Recorder
Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver Logo
46 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
