Question about DISH Network ViP 612
I HAVE DISH NETWORK HOOKED UP IN LIVING ROOM, I WOULD LIKE TO ADD IT IN BEDROOM OFF OF THE SAME RECIEVER. I USED A SPLITTER, THE PICTURE IN LIVING ROOM IS CLEAR, BUT REALLY FUZZY IN BEDROOM. I KNOW THEY WILL BE ON SAME CH, JUST WANT TO WATCH IN BEDROOM.
  • 56 Answers
You will need to split the signal with a 900mgz splitter between the living room and other room. if your pic is fuzzy you have a bad splitter or bad cable, try replacing these one at a time and it should clear up. If your getting a sat pic but ti is fuzzy its for sure in the line somewhere fro teh splitter.
Posted on Nov 20, 2009
  • Chadwick Lowe Dec 02, 2009
    I would suggest hooking your main tv up via HD connections ( componet or hdmi) or RCA if you dont have HD. Then use the tv set out port to run a coax to 2nd tv direct and put that tv on chan 3 or 4. If yur getting a fuzzy pic now with splitter, it could be a splitter or cable issue.
  • DISH Network Expert
  • 246 Answers
Hi ZINISTER300Z there are somethings that can be done to resolve this issue, you want to make sure all yourconnections are tight from the receiver to the TV. And then you will want tounplug the receiver for 10 seconds to allow for full reset and after you plugback in the receiver it will acquire the signal and you will have a clearpicture.
Posted on Feb 02, 2011
Bedroom remote doesn't work
weak batterys wont hold codes on it huh?
Sep 24, 2012 | DISH Network Televison & Video
I have one receiver in my living room. The living room tv is on the #1 channel and the kitchen, guest bedroom and master bedroom tv's are on channel #2. All remotes were working just fine and suddenly...
Hello! On the back of your receiver box you'll see a silver UHF antennae make sure its pointing straight up. If that fails try the steps in this link
http://www.dishnetwork.com/SupportSection/remote-setup
Daniel Busa
DISH Network Customer Service
Jan 04, 2011 | Universal Remote Control DISH Network...
I have anrca hdtv model # R56WH76 and I don't know how to set it up with my cable. I have the dish network box in the living room but this rca tv i have in my room with the cable coming out from the...
To watch Dish Network in your room there a couple of different ways to do it. Unless that cable coming out of your wall is connected to a Dishnetwork reciever its useless.Now if the reciever in your living room is a dual tuner dvr than you can run a cable from one of the two outputs to your bedroom. In this scenario you can watch different channels at the same time. If it isnt a dual tuner then you can actually put a splitter on the cable coming out of the box to the tv(has to be on cable coming out of the reciever) and run it to your bedroom. In this scenario both tvs will show the same channel.In both cases you need a UHF remote(dual tuner DVRs come with one UHF and one infrared) that will allow you to change channels while in your bedroom. If you want HD programing on both tvs you will need to contact Dish Network to get a second reciever. its $7 more a month for a second reciever.
Dec 19, 2010 | RCA R56WH76 Projection Television
I am trying to set up a show to be recorded in my living room. But it records it to the other reciever in the bedroom. I would like it to record to the living room receiver but it won't. It automatically...
Hello! Daniel Busa with Dish Network here! Most likely your reciever is using our record plus feature. This sets the record default to always being on tv1 or always being on tv2. To fix this hit menu 8-5 go to disable hit select, go to done hit select delete the timer and set it up again.
Aug 23, 2010 | DISH Network ViP722 DTV Receiver /...
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
Moving tv to another cable outlet
I f you have cable at the new location follow it back to a splitter. Remove the one you used to use and screw in the one you want to use. They should all terminate at the same location.
Jan 17, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Universal remote
only a uhf remote will work from that location, you will probably need to get a dish network 6.0 or 6.3 remote
Jul 04, 2008 | DISH Network 322 DTV Receiver
Dish network 119
you cannot satellite sginal from a splitter you will need dp 34 switch or quad LNBF DP HOPE THIS HELPS.
Jan 12, 2008 | RCA DISH Network(r) 311 Satellite System
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
DISH Network ViP 612 Logo
386 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
