Question about Xerox Phaser 7760DN Laser Printer
7760 DN printing crooked from tray 5
My Xerox Phaser 7760DN is printing skewed/crooked from my tray 5. It doesn't matter from what software I'm printing or the number of pages. The first page is a crooked as the 100th page. I've changed paper, I just put in new imaging units, checked the rollers, etc. Print jobs from all other trays are fine. Unfortunately, I have to print about 7,000 sheets (newsletter) coming up soon and I need to get this fixed. Help!
  • 1 more comment
  • rylandeb Jan 09, 2008
    Thanks for the suggestion but I tried that, too. I even switched the positions of the specific rollers but to no avail.
    Unfortunately, you can't switch the trays around. It's interesting with this problem because even though it's printing crooked, I'm not experiencing any paper jams or misfeeds of any type.
    I tried your suggestion of only partially filling the tray. It didn't make a difference. I checked the cables that lift the tray and they seemed fine, too. I guess I should probably just call in the Xerox repair guy. I hat to do it, though.
Try cleaning the take-away rollers inside lower left door (door C). These are the long black rollers on the frame. Also try pushing in on the outer edges of door C while printing to see if this makes any difference. If so, you may need to replace door C. Hope this helps!
Posted on Jan 15, 2010
  • 21 Answers
Be careful with rubbing alcohol on rubber it can dry it out and make it crack and then you'll really get a lot of slipping.
Posted on Jan 09, 2008
  • cbri Jan 09, 2008
    Can you switch the trays around to see if one of the other trays work where the 5th tray doesn't work?
  • cbri Jan 09, 2008
    If you fill the tray up to it's maximum capacity does it do the same thing? It sounds like the tray isn't holding the paper evenly (maybe).
  • 233 Answers
Use a little rubbing alcohol to clean the roller for that tray and any rubber part in the area like a "separation pad"
this is a classic symptom of roller/feeding problems
hope this helps
thanks for rating
  • Pedro
    Pedro Jan 09, 2008
    I agree that alcohol will dry out rubber parts but only if you do it excessively, can you switch rollers from the other trays? clearly the paper path is ok concerning drum, fuser and such, so it's happening from the pickup roller up to the drum, somewhere in between there but before the other trays.
  • 21 Answers
7760 dn solo tiene dos trays...
entiendo q la tray 5 sera el by-pass or left tray
la ultima vez q me paso eso es pq hicieron etiquetas q dejaron residuos de cola en el bafle de los rodillos de partida del by-pass, el papel se frenaba por el lado in y torcia el papel
Posted on Dec 02, 2009
  • mocava7 Dec 02, 2009
    los rodillos se limpian bien con agua y jabon de manos
Print Directly to 7760DN from iPad 3 iOS 5.1 ?
Hey I have a xerox wc7328 connected to my andriod. There is a app that is called "printback" from xerox. Follow the instructions in the website where you download the app and its easy. Good luck don't forget to visit us at iteminconline we have all your xerox parts that you need. New and refurb.
Mar 10, 2014 | Xerox Phaser 7760/YDX Laser Printer
Reset fuser on Xerox phaser 7760
You don't need to reset it it. It should automatically reset with no problem you can try to clear the NVRAM . Careful because you will lose all the information you have stored in it like any IP address or specific settings. What it will do is bring the printer to"factory default settings. You can do it in "service diagnostic mode. goodluck
Feb 19, 2014 | Xerox Corporation 7760/Dn - Xerox Phaser...
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
Xerox Phaser 7760. Set document to print as double sided, and it prints single sided. Printing from Mac. Drivers up to date. Any ideas?
There are a few solutions to this problem.
1. The 7760 does not duplex from the MPT 2. The 7760 will not duplex certain paper types eg. envelope, transparency, labels, thick card stock,special. If your paper type is set to any of these it will default to simplex printing. 3. Conflicts in driver settings will cause the printer to default to simplex printing. 4. From the machine settings, duplex can be enabled or disabled. (Though driver settings should override this).
Hope this helps.
Jan 14, 2011 | Xerox Phaser 7760DN Laser Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
I am looking for parts list for a XEROX Phaser 7760 we got a service manual but no parts list need to find feed rollers and one way bearings for # 4 &5 trays ASAP any one able to help
600K78460 Roll Kit (3 Rolls/Kit) but they are the same as a 7750
the bearings don't have no number on the 7760 service manuel.
but you can check this manuel for the 7750 they should be the same.
http://www.office.xerox.com/userdoc/P7750/7750_Web/partslist/index.html
Nov 05, 2009 | Xerox Phaser 7760DN Laser Printer
Xerox Phaser 7750 printing crooked
Follow the solution below, sometimes its a simple matter of removing the trays and checking for paper in the way that may have fallen down behind the trays, also the rollers maybe loose or dirty or old, a good way to clean them is with a slightly damp cloth or some sticky tape, (this gives them some grip). Follow the link below anyway and best of luck!
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=770,E=0000000000024640256,K=470,Sxi=10,Case=obj(21979)
Mar 21, 2009 | Xerox Phaser 7750DN Laser Printer
7760DN is printing pages of jibberish
You can go to Xerox.com and try some different drivers. But most likely you have an issue with the specific software printing to the machine. I would see if a different driver helps, then call 1-800-835-6100 and talk to second level support .
You can also go to the xerox site and click support and drivers, enter 7760 in the search field, then go to the support page, type in Quark in the search field there and see if they have any information there.
Jan 28, 2009 | Xerox Phaser 7760DN Laser Printer
Xerox Phaser 7760DN Laser Printer Logo
493 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
