Question about InFocus SP-LAMP-018 Projector Lamp for X2, C11
Wat buttons do i push on the projector to get the menu on screen? it can turn on but none of the buttons i push will do anything. it's a x2 infocuse projector. wat can i do to fix that?
  • 2,236 Answers
If none of the buttons work, the plug for the button panel board may be loose. remove the rear panel and secure the plug. otherwise, use the remote to get into the menu and factory reset the settings.
Posted on Jan 07, 2010
I need help how to reset my infocus. it can not detached into my computer. I try to set it in menu but I can not get it. some one please guide me how to reset. Here is my email va_lee@sbcglobal.net Thank...
If you have an Infocus LP340 or LP350, you can reset the lamp hours by pressing and holding down the - volume button and then press the menu button (while still holding down the - volume button) for 6 seconds.
Feb 13, 2010 | InFocus SP-LAMP-018 Projector Lamp for X2,...
Infocus X2 projector, white vertical strip on right quadrant.
on the X2, the dmd chip is attached to the main board on the bottom of the machine. you need to take the top case off, as well as the 2 power supply boards. push the dmd chip (behind the lens assembly) back onto the board.
Jun 04, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Doest function.no image projection,fun does not function
fuse on ac filter board. if that's ok, there is a power supply issue.
May 31, 2009 | InFocus PROJECTOR LAMP, Projector Lamp FOR...
Infocus X2 searches won't display desktop
In the projector's menu under "sources" make sure that the box to the right of "Computer" is checked. Also check the box at the bottom of that page that says "auto source select" or something. But it is the last thing on that menu and should be checked.
Cheers
Oct 20, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Sep 01, 2008 | InFocus X1 Multimedia Projector
Only power button responds, nothing else
Hi there
This unit should still be under warranty - take it to your nearest InFocus dealer.
If no signal is picked up then the Mainbaord is faulty.
Mar 28, 2008 | InFocus IN72 Multimedia Projector
PLEASE HELP!!
It also depends what part you need because although the 3 models look similar none of the parts are compatabile with each other except maybe some body parts and the X1 and X2 share the same light tunnel but it would be a risk to assume that the light tunnel from a used model is OK. The only 2 models that share the same parts are the X1 and SP4800. The X2 is brighter and the SP4805 has a 16:9 native ratio.
Feb 11, 2008 | InFocus ScreenPlay 4805 Multimedia...
No picture, no buttons work
unplug for a day and try plugging it
Dec 10, 2007 | InFocus X1A DLP Slide Projector
Vertical Lines on the projector screen
When the vertical lines are displaying, open the projectors menu (by pushing the "menu" button). If the vertical lines affect the menu, it's a problem with the controller board and will need to be repaired. If the menu is NOT affected, it's probably a loose or damaged cable (Cable part# SP-DVI-A-R).
Oct 15, 2007 | InFocus LP70+ Multimedia Projector
InFocus SP-LAMP-018 Projector Lamp for X2, C11 Logo
275 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
