Question about DeLonghi TRD0715T Oil Filled Radiator Heater
Delonghi bam 2.4TE 3yrs old and appears to have faulty thermostat - just stopped one night - thanks karen
Oil filled radiator not hot enough after thermostat replacement
maybe you got the wrong thermostat try fixing the old one or getting a better one
Dec 17, 2013 | DeLonghi Heating & Cooling
Over heating fan oven
it sounds like you tod is faulty its the little stat at the back on the right hand side two wires going to it ok make sure to swicth oven off
Oct 14, 2012 | DeLonghi Ovens
I have Honeywell T8011R programmable Thermostat. Turn AC on last night for first time...working fine...came back late morning to find display and fan off. Check circuit breaker...on. I took it off and...
Hello, first you must verify if you are getting 24 volts to the tstat at the secondary side of the transformer, if not you have a bad transformer. If you are getting 24 volts then check the batteries in the thermostat.
Apr 12, 2011 | Honeywell Programmable Thermostat Heater
I have a Delonghi AM925efy microwave. its only 13 moths old, hardl ever used but its stopped heating anything up. The turtable goea aroun, the light comes on but nothing. no heat. any clues.?? cheers Terry
Thank you for using FixYa. Several things could be the cause.
1. The high voltage fuse could have blown. This looks like a small white cigar tube with a wire coming out of each end.
2. The thermostat or stat. could be faulty. This looks like an oversized watch battery mounted on an oval plate with two terminals on it.
or
3. Inside the micro wave oven usualy on the right hand side, there is a "window" where the microwaves are emitted from- this could be broken.
These are the most commen problems, and are fairly cheap to replace. anything other than these, consider replacing the microwave.
Hope this helps. Please post on here if it does.
Thank you
Duncan
Mar 04, 2011 | DeLonghi Microwave Ovens
My Delonghi DE60PYROS needs a new thermostat, are
Ok get a Service Manual, and the Sensor, and it is not too hard.
Mar 29, 2010 | DeLonghi AS1070 Electric Single Oven
4 ton rheem 3yrs old thermostat
It is possible that the relay in the thermostat for "cooling" has gone bad. The relay that runs the blower is different than the condenser relay. Check that you have 24v AC coming from the t-stat to the "y" terminal at the air handler. That same "y" wire should go out to the condenser, make sure then that you have 24v out there. If you have 24v at the condenser then see if the contactor is pulling in. If not then you may have a loss of charge switch that is stopping the current to the contactor. See if you have 24v to the coil of the contactor. If the contactor is pulling in and power is going to the compressor then the compressor has failed. If this is the case the condenser fan will be running but the compressor is not. If neither the condenser fan or the compressor is running then you have a problem in the 24v circuit, which could be a bad wire or a safety switch.
As you can see there are a number of possibilities for your problem. You will need to methodically go through everything to eliminate the possiblities till you isolate the problem,
I hope that this will help you to solve your problem and get you cooling again!
Thanks for using Fixya!
Heatman101
Nov 23, 2009 | Air Purifiers
Oven has stopped heating up;delonghi oven906gwf
hi this is abhishek,,,,,,,,
its actually a thermostat or its sensor problem check it,,,,,,,,if its not then its a timer problem.......better to fix it
thank u...
May 03, 2009 | Ovens
DeLonghi TRD0715T Oil Filled Radiator Heater Logo
85 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
