Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I recently replaced the gear drive on my craftsmen chain drive opener. However, now the opener only moves a couple of feet and then returns back. adjustments dont work. What is the problem?
    President:
  • 3,197 Answers
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
You should also loosen the chain enough that you can remove it from the sprocket above the motor. Now with the door closed and everything else attached run the motor until it runs clockwise and stops. Replace and tighten the chain. Some adjusting of the up and down limits will be required.
Posted on Nov 16, 2009
It takes 4 or 5 attempts to open first 2 or 3 times it opens a couple of inches then closes light on control flashes red then 2 amber back to red then on about the 3 or 4 attempt it opens a couple of feet...
If you release the garage door manual does it move smoothly up and down or is there some resistance if so your rails my need cleaning or spray oil or the rollers my need replaced if ok then check your chain on the track is to loose and needs adjustment
Mar 24, 2015 | Building Materials
The chain moves but skip gears,how do I fix this
Has the chain been replaces recently? Have you had a wreck recently or laid the bike down on the drive side that might have bent the derailleur hanger?
Feb 16, 2015 | Cycling
Garage door moves few inches and stops, springs are fine, sensros are fine.
If it is not blinking when it stops, then the capacitor is blown. Replace the capacitor and it should resolve the problem.
Aug 09, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Motor hums but door doesn't move. If I disconnect door and give chain a horizontal poke, it will move. When I reconnect door it returns to humming, without movement.
Remove the cover from the motor unit and you will find the drive gear has stripped. White sawdust all over. The part number for the gear kit is 41A2817 and it comes with instructions. It is available at any good door opener service company.
Feb 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsmen garage door is not opening. It started
Your drive gear must be stripped. Remove the cover and you will most likely find lots of what looks like white sawdust and a stripped gear. It is white nylon and is just in front of the motor. The part number is 41A2817 if you want to replace it and it comes with instructions. Available at any good door opener service company.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
1996 chev 1500 pick up chain slips in transfer case under load?
Yes you can just replace the chain, I would not recommend it. Even if it is not obvious, the gears are also worn and have undergone all the stresses that stretched the chain, they may be ready to go soon, why take the chance, the engine has to be torn down to the same point to replace the chain as to replace the gears. I would replace all with a timing gear/chain set and install all new gaskets as it went back together. A timing gear failure could cost you a couple valves and/or pistons when it fails (piston on its way up with a valve stopped at full open when the gear broke).
Please take the time to rate this solution
Jan 29, 2009 | 1996 Chevrolet Tahoe
Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
I have the same problem. I just removed the cover and discovered a nylon gear had been worn out. I found lots of shavings inside the cover. The nylon gear is beneath the exterior chain gear. I am looking for information on how to replace it, if I can find the part. If you decide to look at yours, unplug the power and remove the sheet metal screws securing the bottom portion of the cener cover to the front and back covers. Then just remove the upper screws from the center cover. Good luck.
Oct 08, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Craftsman garage door opener
you can order a new gear kit from amazon for $20. It's and easy fix.
Dec 12, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
160 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
