Question about Curtis Progressive Scan DVD Player 1056
Curtis Progressive Scan DVD 1056A
The buttons on the players and on the remote are not working. If they do work one time it reads invalid key the next time it is used.
  • Anonymous Mar 03, 2008
    iputnewbatteriesinremotedvdplayerwillnotrespond
  • jerkahle25 Oct 10, 2008
    I have the Curtis 1056A DVD Player and I can't turn off the subtitles. Whenever I push the subtitle button on the remote it just says "invalid" on the screen. Ive tried restoring player back to original settings and still nothing. Please help!!!!
SOURCE: insignia dvd/vcr combo progressive scan mode
thanks worked great
Posted on Aug 05, 2007
SOURCE: SD-K530SU - Turning Off Progressive Scan Mode
Sure that's easy, I read this in the manual:
http://tacpservice.toshiba.com/ConsumerProductSupport/Manual/dvd/SDK530.pdf
(Page 18 - Progressive Scan Section)
All you have to do is:
1. Remove the disc in the DVD/VCR.
2. Press and hold the STOP button for 5 seconds before releasing it. (Note that this is the stop button which is physically on the player.)
And that should pull you out of Progressive Scan Mode.
Posted on Nov 06, 2007
SOURCE: How do you take progressive scan off
eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
Posted on Dec 01, 2007
Palmbeach
  • 185 Answers
SOURCE: Diamond Vision Progressive Scan DVD Player
The only Diamond Vision Codes I can find are these.
Hope one works for you.
0622, 0496, 0810
Have a nice day!
Posted on Feb 24, 2008
SOURCE: lh-d6245 dvd player in progressive scan mode no picture
put a dvd into player and let it play, than press stop, sysem show stop, than press stop again for 5 sec, and the LG screen will be back to tv screen.
Posted on Mar 21, 2009
I just bought a Curtis 1041 dvd player I set the player up I am receiving sound from the DVD but no picture. What is wrong
hi,
connect the dvd player to the tv insert a disk then press the progressive scan (proscan) button on the remote control. If the progressive scan is on then there is a possibility of video missing in some tv's. If then also there is no video then you have to check the video cable. Try with some othere video cable.
If the problem previes after replasing the video cable then the video processor in the dvd player is fauly. You will not get this video processor in the oppen market. Only way is replasing the board.
ok
Sep 24, 2011 | Curtis DVD1071 DVD Player
Need to turn OFF progressive scan on Sony DVD DVP-NS57P
With the remote: While in STOP mode, press the DISPLAY button. Use up/down buttons to select SETUP. Press Enter. Use up/down buttons to select CUSTOM.Press Enter. Use up/down buttons to select SCREEN SETUP. Press Enter. Use up/down buttons to select PROGRESSIVE. Press Enter. The manual is a bit indistinct after this, but I think the prompts will direct you. Just turn Progressive OFF.
Owner's Manual page 61, link http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/DVPNS57P.pdf
Nov 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
I have a Curtis Progressive Scan DVD 1056.
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Curtis DVD player.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Dec 29, 2007 | Curtis Progressive Scan DVD Player 1056
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
Cannot remove progressive scan mode
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
GoldStar DVD/VCR-progressive scan mode problem...``
Remove any DVDs from the disc player. You should be in Blue Screen mode on the TV...If it says "Progressive Scan Mode" ....make sure there is no DVD in it...close the disc changer and push and hold the "Stop" Button on the player, not the remote, for 5 seconds or longer. This has been proven to work every time!!!
Apr 10, 2007 | Goldstar GBV241 DVD Player/VCR
Locked into progressive scan AND Setup is Unavailable
The key is to make sure you REMOVE all DVDs and VCRs from the player, then hold the stop button on the unit down for 5 seconds.
Oct 23, 2006 | Zenith XBV442 DVD Player/VCR
I can not turn off the proggressive scan!
Try this to disabel the progress scan mode: Pointing the remote at the player, press the STOP key to stop any disc that is playing. Next, press the STOP key again and hold it for five seconds before releasing it. This should turn the Progressive Scan off.
Oct 05, 2006 | Zenith XBV442 DVD Player/VCR
Curtis Progressive Scan DVD Player 1056 Logo
180 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
