Question about Mitsubishi WS-55511 55" Rear Projection Television
My son was moving his WS-55517 and during cabinet
My son was moving his Mitsubishi WS-55517 rear projection TV and during cabinet separation he failed to disconnect the mating cables. This resulted in destroying the cable with the shielded case that contains four wires. The connector was pulled from the lower cable. This cable connects to the lower electronics and looks like a USB to firewire cable and is about 30 inchs long. Note...it is not a USB cable, but looks similar.
Can a replacement cable be purchased and is so, what is the part number and where can it be purchased?
I believe I can solder the four wires back to the connector, but I have no idea what the pin-to-pin connections are. What is the pin to pin wiring?
  • Mitsubishi Master
  • 1,213 Answers
You better take this TV to the Hospital. A local tech will be able to explain to you what needs done. This is the best solution, as you can certainly make things worse.......And its safer!!!!
Posted on Nov 16, 2009
5551355 green light blinking capasitors are bad need to know number on capasitors
well, I fix it my ws-55517 and I changed 4 capasitor from DM Board, numbers :C81..C81a..C82b...C81c....1000ufd,16v,105c
Jun 21, 2014 | Mitsubishi WS-65869 65" Rear Projection...
RELENTLESS SNOW
You shouldn't have to have the tv to channel 3 or any other for that matter if you are in component. You need to make sure the tv is on the component input from your display menu that can be accessed from your remote.
Nov 12, 2013 | Mitsubishi VS-60805 60" Rear Projection...
How do i disassemble my ws-65313 for transport
Good Day,
To disassemble this TV follow these directions:
1). Pull front speaker grill off
2). Unplug the 2 cables connectors in front
3). Remove 4 screws on both sides of cabinet (might have plastic covers)
4). Carefully lift cabinet top until the support tabs clear the bottom cabinet
5). Carefully rotate the cabinet top and place back side on floor ( the mirror is on the top side)
6). Pack/wrap properly with blankets and transport in this manner.
Good Luck and Move, Big Irish.
Dec 02, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Is there any way to split the tv in two pieces for
I do not see any way to divide main wooden box of TV as you can remove front screen and back cover of TV but main cabinet of TV still remain the same.
Check below exploded views of WS-65313 for better explanation.
Thanks.
Oct 30, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Shuts off after 15 minutes
Most likely you have picture tube coolant leakage on the power board. Have an authorized Mitsubishi service shop take a close look.
Apr 06, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Ws-65869
Existen unos capacitores que con el tiempo fallan y te dan el sintoma que tienes en tu TV. Estos filtros o condensadores estan localizados en la placa DM (Modulo Digital)
Presione Aqui donde se encuentran instrucciones de como y donde se encuentran los filtros.
Las instrucciones estan en Ingles pero hay fotos tambien.
Aug 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Relocating tv
Yes, this set does come apart for moving. Remove the lower screw from each side of the TV back. On both sides, pull off the two plastic caps and remove the two exposed screw. Lift the cabinet top straight up until the guide pins clear the holes in the bottom cabinet. Be careful and don't drop anything.
May 03, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
