Question about Dualit Vario 4 Slices Toaster
All slots not heating - Dualit Vario 4 Slices Toaster
  • 1,711 Answers
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Posted on Apr 02, 2010
How to remove heated rear-vision mirrors glass only
most mirrors have push pins holding the top of the glass to the movable backing plate and 2 lower tabs that slide into slots first.
gently pry on the top of the glass toward you and the glass should release .then lift up to get the tabs out of the bottom 2 slots.
Mar 29, 2015 | 2008 Jeep Commander 3.7
Kenmore dryer does not heat
Find a volt-ohm meter you can use.
Unplug the dryer and test the socket on the wall or on the floor for current. If If you have a 3 pronged socket, the two slanted slots should have 110 volts each, and the "L'' shaped slot is your ground.
If you have a 4 pronged socket, the two straight slots are 110 volts each, and the "L" shaped and the round slots are grounded.
If you do not have 110 volts showing on both slots, you likely have a blown circuit-breaker to reset at your fuse box.
Depending on the year of the dryer, you have the following things to check inside the back of your dryer.
Wiring, for burnt or broken wires, the heating element for a broken wire, and 2,3,4, or 5 thermostats.
Unplug your dryer and remove the back so you can see all the wires and the above parts.
One at a time, remove the wires from each thermostat and see if the thermostst is blown.
You can tell by setting the volt-ohm meter to ohm's resistance, that's the "Infinity" sign.
Check the heating element the same way.
If the thermostat and heating element are good, the needle will go up on the meter. If one is bad, the needle on the meter will remain motionless.
Each of the thermostats and the heating element are removeable, and replaceable.
Be blessed.
Jan 24, 2013 | Dryers
PCIe slot 3 not working on gigabyte MA785G-UD3H
Dear,
first of all remove the VGA card and replug it...it should solve the issue. If the problem persists, then clean the slot with air blower for the possibility of dust and also clean the vga card bottom pings (gold coated) with some eraser as eraser will remove the contaminated material on the pins without harm anything...
good luck!
Apr 01, 2012 | Gigabyte Computers & Internet
You have to put a lot of weight on the heat sync for it to boot up
I would assume that it's the cpu heatsink? Actually, it's a bad thing to put extra weight on the heatsink for it may damage the processor. The spring and locking mechanism of the heatsink is just enough to transfer the heat from the processor to the heatsink. Problem maybe on your processor not properly seated on the slot. Remove the heatsink assembly, and release or remove the processor from the slot. Check if there's a foreign object in the slot, a brush will do the cleaning. Reinstall the processor and the heatsink assembly.
Sep 06, 2010 | Dell Dimension 4700 PC Desktop
Ge jsp42 electric range ..Oven heats up very slowly..sometimes can take one hour to heat to 400 degrees..Stove top also slow..
Check the voltage at the outlet. It should be 208v or 240v. check by putting meter probe into the 2/3 slots. NOT the U shaped,or round looking holes.Check one to another. Check tag on range for voltage of range. If you have 208v at the outlet and range is 240v the oven will take forever to heat, it is not getting the power it needs. If the tag says 230v either will work. On the oven tag it will say either 1ph, or 3ph. If it says 3ph you outlet should have the voltage mentioned above between ALL 3 SLOTS! If you get 120v when testing any slot, you have only 1ph of power. Keeping it simple, the ph, (or phase,) between the outlet and oven have to be the same.
Mar 31, 2010 | GE JSP42 Electric Kitchen Range
The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Apr 05, 2009 | Dualit CTS4E 4-Slice Toaster
Heating problem
Intel D102GGC2 Motherboard
i am having 1GB Ram in Single slot,when I add another 1GB ram in the other slot the memory shows only 896Mb.The processer is dual core.
Dec 05, 2008 | Intel D102GGC2 Motherboard
Light does not come on, nor does it heat up
Some fryers have safety switches on the heating element, this is so they can not be turned on when not properly installed into the unit. Check to see if there are grooves or slots on the side of the fryer which correspond to grooves or slots on heating element. Then slide the heating element into the slots on the fryer.
Safety switch in most cases can not be seen and can not be disengaged by hand. The heating element must be installed properly in order to work. It may be illustrated clearly in the owners manual.
Do not try this with out oil in the Fryer!!
Nov 14, 2008 | Kitchen Appliances - Others
Dualit 4-slice toaster (84US) warms only slightly
please check and make sure the red button in front is pressed to the right so that all 4 slots will heat up.
if it is to the left, only the left 2 will heat up.
if you need additional help contact the service center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Nov 01, 2008 | Kitchen Appliances - Others
Dualit Vario 4 Slices Toaster Logo
104 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
