Question about DCS Kitchen Ranges
DCS RANGE MY DCS STOVE WON'T FIRE UP. THE BURNERS CLICK WHEN I TURN THEM TO ATTEMPT TO TURN IT ON.
  • murphysworld Nov 16, 2009
    THE STOVE IS 5 YRS OLD. I DON'T USE IT VERY MUCH SO IT'S A SURPRISE IT'S ON THE BLINK. WHERE IS THE REGULATOR ON THE STOVE? THX
    THANKS VERY MUCH
  • 6,927 Answers
Well,we know there is no gas,check and make sure the gas valve is on in the rear.Was this stove just put in?If so,the gas has to bleed the air out first.Look to see that there is no leaks in the stove.If the regulator senses any leaks,it will cut the gas off.If there are no leaks,and the gas valve is on,replace the regulator,it has stuck in shut down.Look for a reset on the regulator,to reactivate the regulator.If a stove eye,or oven burner was blown out by mistake,it would have shut the gas off.
Posted on Nov 16, 2009
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 16, 2009
    Should be in the rear,follow the gas line from the floor,or wall,it will take you right to it,It may just need bleeding.
  • Ronny Bennett Sr.
    thank you
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
DCS RGS slow to preheat
You didn't state whether you used a DCS conversion kit or not. I was able to find conversion instructions for a model similar to yours (not an exact match) but it will give you an idea as to what all is involved.
DCS RGSC 305 Instructions Manual
Dec 14, 2017 | DCS RGU-364GL-N Professional Series 36"...
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
My oven won't heat up and just smells like gas but my stove burners work
Hello, This is going to be a problem with your igniter/glow bar. Over time these get old and although you may see it glowing iit still may be bad. Your igniter should glow a brillient yellow and should ignite the gas within 15 seconds of the valve opening. If you have any other questions or concerns please feel free to comment again...Good Luck! Mike
Aug 17, 2009 | DCS RGS-305 Professional Gas Kitchen Range
DCS Range constant sparking at all burners even when lighting one
This happens to mine if there is anything on any of the burners, such as food residue or moisture. Check all the burners to see that nothing is touching the burner area where the gas jets are. Even a little water can make this happen.
Jan 02, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
DCS stove igniters clicking
Actually Dave, when you turn on one burner, all of the igniters do fire. This is normal. Perhaps you never noticed it before. regards, Joe
Dec 19, 2008 | DCS RGS-486GD Gas Kitchen Range
Dcs gas oven/range, ignitor won't go off after burner or burners are lit
They probably cleaned the stove and in replacing the parts of the burner switched the rings on top of the burner. This happened to me. While they look alike, the round rings, not the flat disks, have to be on the right burner in order for the electron spark to ignite the gas. Good luck.
Oct 29, 2008 | DCS 24-24G-1 Gas Kitchen Range
Amana oven and broiler won't fire
Check your stove breakers first. Click them off, leave them off for a minute and put the breaker back on. It sounds like you are having a power supply problem. Make sure to check your potlet and power chord as well.
Jul 08, 2008 | Amana Kitchen Ranges
Kitchen Ranges Logo
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
