Question about Bronica SQ-Ai Medium Format Camera
Bronica SQ A The plastic 'double exposure' lever is broken and I would like to make a new one. Im thinking about using a spare which I have for a mold. I used silicone putty but that was no good. Any hints?
  • 667 Answers
I doubt if you will find a suitable material unless you switch to making one out of metal. Brass would be my choice.
Posted on Dec 07, 2009
Shutter will not cock
Hi there
I have researched your problem. I have located the online version of your camera and attached the link here:
http://www.tamron.com/assets/pdfs/SQ-A.pdf
It seems like the following cause might fit your symptom:
Is it possible that the small lever on the side might be set to multiple exposures. (See number 22 on the online manual that I sent the link for!)
Good Luck! and let us know how this works.
Jan 04, 2008 | Bronica SQ-Ai Medium Format Camera
Zenzanon 80
The lens does not have a shutter - that's in the camera body. The lens contains the aperture or f stop adjustment. It is done by injecting or retracting blades in the light stream of the lens barrel between the front and rear optics. Check the aperture blades to see if they move easily and open equally by varying the f-stop ring on the lens while looking through it. If not moving all the blades the same amount or it does not continue to restrict the opening as you increase the f-stop value, there's something wrong with the lens.
Are you sure you haven't accidentally activated any exposure compensation adjustment on the camera body?
Jan 10, 2012 | Bronica 80mm f/2.8 Zenzanon-PS Lens
Camera cocks but will not fire. New batteries
Is there film loaded? Bronica cameras feature an interlock that will prevent the camera from fully firin when not loaded, when no back attached, or when the dark slide is in the back. Some models have a small flip-switch that doubles as a double-exposure switch on the side that can be used to dummy fire the camera to test fire it.
If that doesn't work, consult a tech. The electronic's in these cameras go bad qute often these days.
Jun 15, 2011 | Bronica SQ-Ai Medium Format Camera
Just starting out with medium format. We bought a second hand Bronica SQ-A from a reputable dealer but the shutter will not **** in 'Normal' 'single exposure setting'. Cocks fine in Multi-exposure setting,...
Sounds like a problem with the single/multi "switch".
Film should not wind on in "multi" setting.
Back to the dealer - if he is reputable, he will get it fixed.
Dec 26, 2009 | Bronica SQ-A Medium Format Camera
Film winding handle missing
Depending on where you live, your best bet is one or more of the following: 1) eBay 2) your nearest Tamron distributor/service centre (Tamron bought Bronica in the early '90s and may still cary spare parts). 3) local camera repair centres
Mar 22, 2009 | Bronica SQ-A Medium Format Camera
Bronica sq-b, mirror lock up lever was broken
Hi, I have the same problem - my lever plastic become broken in 2 days after I'vet body from KEH. Seems that iron topof the lever can be screwed in counter clockwize direction and after new one lever installed it can be screwed back and fixed with rubber cap.
But question to you - where did you get the replacement?
You can contact me on nkir@mail.ru at any time.
Regards,
Kirill.
Dec 22, 2008 | Bronica SQ-Ai Medium Format Camera
Shutter not Cocking?
Try removing and re-attaching the lens. IIRC, the actual shutter mechanism is part of the lens assembly
Jun 19, 2017 | Bronica SQ-A Medium Format Camera
120 film backs
skip frames or overlapping(multiple)exposure is caused by the film advancing mechanism. if you treasure your camera y back. send it for service.
pc-cook
Oct 10, 2007 | Bronica ETR-Si Medium Format Camera
Bronica SQ-Ai Medium Format Camera Logo
176 people viewed this question
Top Bronica Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Bronica Photography Expert? Answer questions, earn points and help others
