Question about Humidifiers
No coolin in the freezer nor in the fridge
The lights are on.no coolin in the freezer nor in the fridge.
last november 1 was charged for 1880 for gas filling, drier etc.
again i'm encountering the same problems.
  • 78 Answers
Compressor
Posted on Nov 16, 2009
Need online instruction manual for hankscraft humidifier model 240
I found this. There are no manuals available on line.
Here we have a used working HANKSCRAFT / GERBER COOL VAPOR HUMIDIFIER Model 240 WITH INSTRUCTION MANUAL and STEAMED CLEANED. This humidifier, by Gerber, has a 1 3/5 Gallon Capacity, and produces cool vapor for up to 18 - 20 hours in low, medium or high settings. The humidifier works great , does not have the directional nozzle included but does come with a copy of the instructions.
http://www.ebay.ca/itm/331790662762
Dec 03, 2016 | Humidifiers
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 | Humidifiers
Our Kenmore 50pt dehumidifer is less than 2 years old, only used for 1 summer, tried to use it last week, it starts/runs but does not withdraw any water, please help. Thanks kindly
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you unit is manual control,
turn the control knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter. Filter should be cleaned once every 2 weeks.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Humidifiers
Output/Fan will not turn no matter what setting the speed control dial is on. Blue light and green light go on when humistat knob is turned. I purchased this humidifier in November and it was working...
Sorry to read about your problem, I hope this helps you out.
You either have a defective power switch, or defective motor, your unit is under warrenty, so I suggest you return it..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Honeywell HCM800 11 Gallon Humidifier
How to reset the humidifier when the green light change to yellow ?
You just turn the switch to off and let it sit for a few minutes. Then when you turn it on again it will be green. I turn it off when I take the tank off to fill it and by the time I return, it has reset.
Nov 25, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
Got it on Craigslist
The red light indicates that there is no water in it. You need to put water in it, then a green light comes on instead. When the water runs out you will see the light turn red again. You need to fill it about 2/3 - 3/4 of the way up to make it last.  You should refill it about once a day or every 2 days depending on how often you use it. But when you see the red light on then you know the water is gone.
May 03, 2008 | Crane Frog EE-3191 1 Gallon Humidifier
No steam comes out
I just took mine apart and cleaned the scale off the heating elements. Filled to the level with hot water and it was steaming good in about 2 mins.
Mar 01, 2008 | Vicks V150SG 1 Gallon Humidifier
Water is constantly filling
Have you checked the position and function of the floats in the pan?
Nov 20, 2007 | Honeywell HE440A1005 Humidifier
Humidifiers Logo
29 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
