Question about Mitsubishi WS-55809 55" Rear Projection Television
I want to know if you have to turn on the HD conponents cause i tried to use my xbox360 and thier is nothing on the screen. i already check the xbox360 wires and they are fine.
  • 456 Answers
If you are using a high def tv and u want to play with hi def graphics, u must put the switch on the xbox av/component leads to HDTV, otherwise,standard def will be used. Check the tv input by using a dvd player or another input source to confirm it works. Good Luck.
Posted on Nov 16, 2009
How do i get my nintendo wii console to appear on the tv screen ive tried every channel and hdmi and such and nothing i know its on and working cause i feel the wii remote vibrate just nothing shows o
Kate what did you plug the cables into I suspect it was a grey cable with a red , white and yellow plugs. If I am correct this cable should be plugged into the AV1 or AV2 input port of your television. Try changing the input source to AV1 or AV2 Check it is plugged to AV1 on the Television and not into Conponent input !
Jan 02, 2015 | Sceptre X32BV-Naga 32 in. LCD TV
How do i fix the green screen on my JVC HD-55G466
I know it sounds stupid, but could you have pushed the input button on your remote, changing from say, input #1 where the cable or satellite is connected, to an input nothing is connected to? That would cause the screen to be either blue or green I think. It's worth checking. I've done it myself! Good luck! Hope you get it figured out soon. Bill
Aug 01, 2014 | Televison & Video
Hi everyone, Im new to this thread, but I have very high IT experience. However, I have a problem that I just cant figure out. My Dynex tv randomly started acting up. All my colors and channels are...
check the connection to your tcon board and main av board. if the connections are good one of these boards is more than likely bad. Google their part numbers and see if that board has a known issue
thanks,
michael
Apr 05, 2011 | Dinex DX-LCD26-09 26 in. HD-Ready LCD TV
I have a Sharp LC-52-d64u tv and it wont turn on
I have this same tv... Have you played any video games on it cause the xbox360 makes the screen blank... Put an hdmi cable in you tv and connect it to your cable box or dish box... this might fix the problem
Apr 06, 2010 | Sharp LC-52D64U 52 in. LCD HDTV
I replaced a bad hard drive , now I can't instll any OS. I get blue screen in the middle of a install. What do I need to do to install a OS?
Blue screens mean that there is a hardware issue. Disconnect all peripherals (usb, printers, etc) and try the install again. If you get another Blue screen, then there is an internal hardware error that would need to be addressed by a service technician. You can try re-seating all of the conponents (RAM, HD, etc) but this rarely helps.
Dec 31, 2009 | Acer Aspire 4720 Notebook
When my xbox360 play's a movie i get half of screen
Did you check the video cable on the back. Switch it to HD if it is on TV
Jun 08, 2009 | Microsoft Xbox 360 Arcade
Hd problem with xbox 360. works through SD but black screens on hd channel. i took xbox upto friends house who has 1080p tv but never changed the setting when i put back to my tv. would this be the problem...
Thats the problem sometimes the Xbox360 can change that by itself but in your case i think your best bet is changing it back with your friends HDTV. Also i would try hooking up the cables one more time on your tv but make sure you turn on your xbox after all the cables are connected. But its nothing major its a really easy fix. good luck and let me know if you still have the problem.
Oct 02, 2008 | Video Game Consoles & Games
Xbox360
well it seems that your xbox is well and truely broken. contact microsoft and tell them whats happened and if you have done nothing wrong to cause your 360 to break then they will repair/ replace your xbox for free
Jan 05, 2008 | Microsoft Xbox 360 Console
Three flashing red lights
this means your system is not properly conected also on yor video conponent check to see if its set on tv or hd mess around with it
Jan 03, 2008 | Microsoft Xbox 360 Console
Use the "HD Selector" on the cable that plugs into your xbox360 and make sure it is pointing to "SD" and then turn on your xbox360. This should put the console in standard definition mode and allow you to see the picture on the screen. If this doe not work, check and make sure you are using the proper inputs on your tv and selecting those inputer accordingly.
Jul 05, 2007 | Microsoft Xbox 360 Console
Mitsubishi WS-55809 55" Rear Projection Television Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
