Question about Sylvania 6427TE 27" TV
Srt4127f remote will not work?
All functions work manually,the remote will not operate the set.
  • Anonymous Feb 01, 2009
    Same problem as original poster. No universal remotes work either, so it's the remote sensor inside the TV.
I have the same problem, I believe it is not the remote but the receiver in the tv, in the process of trying to replace it. told it is not hard to replace.
Posted on Feb 03, 2008
I don't have an answer but have the same problem. Apparently this is a common problem with sylvania tvs any suggestions anyone???
Posted on Jan 19, 2008
My tv won't take commands from my remote, it will shut down, but not restart
If you are using a none original remote then not all remote codes will work all the functions. Some codes are designed for different models. So you might have to try several codes before all functions will work. Even then some might still be missing.
If you are using a new genuine remote and it's still playing up. Then either two possibilities can occur. The set has been switched to work a different remote. Or there's a fault in the set that has either effected the remote functions or has caused the functions to cease to operate, even though the remote is sending out the correct signal and the set has received it.
Sep 25, 2016 | Insignia Digital-to-Analog Converter for...
Tadiran GXL-2027 HDE Need manuals and remotes to operate all equiptment is missing.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Jun 02, 2016 | Televison & Video
Need to set Sony remote to work with new t.v.
You need to set the code for the TV. Follow the instructions in the remote's users' manual on how to find it and set it. If you don't have the manual do an Internet search.
Good luck & please let me know how you do.
May 27, 2014 | Sony RM-EZ4 Universal Remote Control,...
My pioneer pro 1140hd elite remote is not functioning. A spare remote doesnt' work either so it must be the tv itself. How to fix?
If the remotes have both been tested (shops can check with a tester all buttons) you may have a remote receiver in the set that is bad--some the remote will not work or only works with remote very close to set.
Many digital cameras in a very dark room will react the same way when a remote is pointed at them and buttons pressed---a faint flash on the camera display.
Dec 03, 2012 | Televison & Video
My Onkyo DR90 DVD Remote Will Not Operate Components
Your Onkyo DR90 DVD Receiver remote control does not have universal remote functions, and cannot be (easily) programmed to control a Panasonic DMR ES15. Your DR90 remote does have a limited learning function, but it is designed to learn the codes from your TV's remote to control the TV. Only the following buttons are programmable by the TV Learning function:
I hope that helps.
Onkyo DR90 DVD Receiver User Manual Download.
Apr 14, 2010 | Onkyo DR90
Looks like a common frequency and coding problem. Try to keep the TV and Cable box far away and try the remote. If it works, then, escalate to Cable operator for providing a new box with remote or ask for a different brand of cable box.
Jun 10, 2008 | Protron PLTV-37 37 in. LCD Television
Remote for the 3800
I assume you were just entering manufacture codes. Some times this won't give you all the features you're looking for (like skipping tracks). Try going through the manual to assign buttons a particular function. It's a learning remote so it can learn from your other remotes by putting the two facing one another and going through the necessary button sequence laid out in the yamaha manual (page 104 in the RX-V1800 manual, it's in the advanced operation section)
CAUTION: All buttons are reprogrammable so make sure you have your source slider (on the right side of the remote) set to Source and not AMP or you'll overwrite the Amp functions and you'll have to reset the remote to factory settings and start over.
Oct 14, 2007 | Yamaha RX-V3800 Receiver
How do I switch to Av manually?
You may have to get an exact replacement to get ALL the set's functions to operate. Universal remotes don't let you access all the functions of some TV's If you can use the buttons on the front of the set to bring up the menu, you may be able to scroll through it and find where you can select the type of input you want. You would select AV. Stargazer
Aug 19, 2007 | Bush 2871NTX 28" TV
Sylvania 6427TE 27" TV Logo
178 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
