Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Standby light flashes 50 times then lamp light flashes, no picture or sound
Standby light flashes 7 times then lamp light flashes, no picture or sound
Posted on Dec 19, 2009
No picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
May 05, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Green standby lamp flashes but power light does not come on and there is no picture
Here you go:
http://www.highdefforum.com/rear-projection-tvs/109533-flashing-green-standby-lite-then-flashing-red-lamp-light-sony-wega-50-xbr.html
Dec 05, 2010 | Sony KDF-E42A10 42 in. LCD Television
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
I got a replacement lamp, but red light still binks and there is no picture. Why?
hello if the lamp cover is not mounted securely the self -diagnostic funcation works and the power/standby indicator flashes for 3 times .when you've corrected it the power/standby indicator goes out and the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
Jun 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Oct 20, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
230 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
