Question about Samsung RB2155SH Bottom Freezer Refrigerator
Samsung RB2155SH ice build up temperature drops
Samsung RB2155SH i. I recently had this repaired, and I knew what they did couldn't be right. They replaced the mother board (a $200 repair item). But now, the problem persists- ice buildup and temperature drops. I'm pretty sure it's a defrost problem, but not sure where to tackle it from. I'd like to fix it myself and just need to know which part to replace. Thank you!
  • lollipopluv Nov 16, 2009
    Thank you SeaBreeze. I'm going to read through this to see how to get to the PCB box and test it, and I will let you know what happens.
  • Samsung Master
  • 43,501 Answers
I would change the sensor assembly it is part #4 in this diagram and only a 10.00 part. Seems like it may be the problem.
http://appliancehelp.com/Search_Model_Results.aspx?ModelID=283832&ModelNum=RB2155SH&mfgModelNum=&ManufactureID=1&Selected=58242&Position=0&mfg=Maytag&Type=&Mark=0
Posted on Nov 16, 2009
Testimonial: "I will try that and let you know if it works. Thank you!"
  • Samsung Master
  • 4,654 Answers
I will give you a shot at it, let me go and get the service manual and look over the complete electrical defrost controls. Sea Breeze
  • John Tripp
    John Tripp Nov 16, 2009
    Click here for the service manual=> RB2155SH Go to page 51 and read the procedure for manually forcing the refrigerator into defrost. If to board is good you may be able to do this. I need to know if it is still under warranty. 5 years sealed system? If the defrost heater is bad we have a problem so let me know what you find. Maytag sent out a service bulletin on that model because if the defrost heater goes bad they need to replace the complete evaporator. Click Here=> Defrost heater Repair I hope it's OK but we need the eliminate that first. I can help you the best way I can if you want to try and check some test points. Let me know here or HERE. Thanks, Sea Breeze
  • John Tripp
    Thank You! If you run into problems let me know. These refrigerators are complex even for the best technician. Even if I could not walk you through each step I have a friend that that can. But I won't post any names here. You would need to contact me at the Let me know HERE before I signed off last time, Thanks For The Rate! Sea Breeze
Samsung bi-metal defrost thermostat
If the coil is good, it could be that the defrost timer is not allowing enough of a defrost cycle resulting in ice buildup after various cycles. The ice is never being complete melted and it just keeps building up.
Mar 13, 2017 | Samsung Refrigerators
Samusung RB2155SH Bottom Freezer stops cooling.
I'm having the same issue. Were you able to get this fixed or did you just buy a new refrigerator?
Feb 24, 2013 | Samsung RB2155SH Bottom Freezer...
My freezer ( Samsung RB2155SH) is not getting cold enough,do i have to replace the mainboard. Please advise.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | Samsung RB2155SH Bottom Freezer...
My Samsung RB195BSSB bottom freezer model has recently developed an issue. The freezer will warm up to 21 degrees and not hold the previous temperature. Fridge is fine. Ice maker may not be making ice...
This sounds like there is a build up of ice on the evaporator. this will block the air flow and allow temperatures to rise.
The problem could be with;
\ the defrost timer
\ defrost heater
A technician can solve this for you
Mar 24, 2011 | Samsung RB1955 Bottom Freezer Refrigerator
Samsung refrigerator had water leaking into bottom
Is he an authorized Samsung/Matag Repair Center Employee? And I believe I know the answer. But you need to communicate with me, OK? How old is your model?
Thanks, Sea Breeze
Apr 09, 2010 | Samsung RB2155SH Bottom Freezer...
Ice block forms bottom of freezer then leaks on 2 floor
This is usually because the self defrost hose has become clogged. Turn the unit off long enough to defrost the unit and get the ice out of the tube and blow out the tube and turn the fridge or freezer back on.
This should solve it for you.
Cheers
Al
Sep 11, 2009 | Samsung RB2155SH Bottom Freezer...
Samsung american fridge freezer not making ice what can I do? Ice tray is on its side
If Samsung I need the model number to begin to help. There are so many I would only be guessing to give answers. Check for a model like RB2155SH for example. Sea Breeze
Jun 20, 2009 | Samsung Refrigerators
I have a Samsung American style side by side fridge freezer - not plumbed in at present. The freezer works ok but the fridge ices up in the bottom half and the overall temperature will not drop on the...
these samsung are liable to ice forming around the fan and jamming it.
take the backplate off inside the fridge and melt the ice off with a hairdryer. make sure the fan rotates freely as well.
if memory serves me right, samsung did a mod to prevent this
Oct 20, 2008 | Samsung Refrigerators
Samsung RB2155SH Bottom Freezer Refrigerator Logo
711 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
