White Westinghouse Model No WTV 11901 television
White Westinghouse Model No WTV 11901. Dont know where I hook up a DVD player, cant see any place to put cables
  • Anonymous Mar 15, 2014
    I have a white Westinghouse television wtv-12505. I lost the original remote. How do I get to the video option so I can watch video's?
  • 192 Answers
It sounds like your TV is not equipped with audio/video (A/V) jacks. Many older TVs don't have these. You need to get an RF modulator that will convert the A/V output of the DVD player into a Coaxial cable that you can plug into the back of your TV. I'm including a link to one at Radio-Shack.com. This one costs $27.49. You might be able to find a cheaper one at a discount store. You can also use an old VCR if you have one to do this conversion but the connections get a little bit tricky. Plug the A/V outputs of the DVD player into the A/V inputs of the VCR. You'll have to set up the VCR so it knows to use the A/V inputs. Some VCRs have and AUX setting for this. Then connect a coaxial cable from the VCR output to the TV input. You'll have to setup the VCR to send it output to a specific TV channel, usually channel 3 or 4. Then you'll have to set your TV to that channel. I hope this helps you out.
http://www.radioshack.com/product/index.jsp?productId=2103095
Posted on Nov 16, 2009
  • 66 Answers
Check the back and side of your television or else in fron for the cables connection
How do I hook up this DVD player to my 60 inch Westinghouse model #VR-6090Z ?
If your DVD player has HDMI, use it. If not, you'll need to buy a cord for it. Look on the back of the TV and the back of the DVD player. There should be colored connectors on each one. On the TV, it will be an input. On the DVD player, it'll be an output. There will be either 3 connectors or 5 connectors on the TV and DVD player. You'll need a cord with either 3 connectors on each end (red, white, yellow), or one with 5 (red, white, blue, green, red). Once you figure out which cord you'll need, buy it from any store that sells TVs and hook it up. The link below has pictures
Video Connectors Tutorial Hardware Secrets
Feb 02, 2015 | Westinghouse Televison & Video
I just bought a Westinghouse LED TV. When I hooked up my dual DVD/Video combo the picture is black and white. What did I hook up wrong??
It sounds like you may have connected the dvd/video combo to the wrong spot on the television. The yellow wire cannot be placed into the green hole. You'll get a picture but it will be in black and white. You can only connect these yellow, red, and white composite wires to a component input spot on this television in order to get a color picture.
Aug 21, 2011 | Televison & Video
Westinghouse plasma tv is hooked up to a memorex dvd player ,that won't allow me to watch the DVD in color only black and white, what am I doing wrong?
There are a few more details to discuss on this, I need to know what Westinghouse model # you have, also how the DVD player is connected meaning Component, Composite, HDMI, etc. Please send me a quick email to westytech@westinghousedigital.com so we can troubleshoot this problem.
Jan 31, 2011 | Televison & Video
They did not include the cables in the box bought from overstock Westinghouse 26" LCD HDTV SK-26H730S where can I get them?
Cheapest place to buy cables would be from monoprice.com
If you would like I can give you a list of suggested cables to use for the best picture/sound. I'd just need to know what the make and model of any other equipment you are trying to hook up to the TV is. i.e.
Sony DVD Player: DVP-D2700
Denon Reciever: AVR-391
Jan 07, 2011 | Westinghouse Televison & Video
Hooked up DVD player to 32" Westinghouse HDTV and now all dvd's are in black/white and fuzzy, along with only having 3 total channels! Help!
It sounds like something is shorting out do to an incorrect connection. Make sure you are matching the correct colors if using composite (RCA) or component cables.If you are using composite than hook the yellow for video and red and white for left and right audio. For component cables use the red blue and green for video instead of yellow and use the red and white from the composite cable for left and right audio leaving the yellow unplugged. You should have the cables coming from the DVD players output going to the TV's input. Select the same input on the TV that you have plugged into. If you are using coax cable through the DVD player if it has a tuner than you will need to change the TV to channel 3 or 4 depending on what the DVD is switched to. After you are done with the DVD player be sure to turn the power off so the cable can work properly. I am guessing here since I don't have much info to work with so I hope this helped you.
Nov 29, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse model WTV-11901 shuts off by itself
That is usually a bad power board, the TV can be turned on again after a while because the capacitors inside TV will discharge after some time. The part must be tested before replacement, as overheating can cause similar problems.
Try also leaving the TV unplugged from main overnight, and test the unit on a different AC socket.
May 15, 2009 | Televison & Video
White westinghouse tv model wtv-1903
The display button on your remote should remove this.
Oct 22, 2008 | Televison & Video
Comcast universal remote codes don't work for zenith zhd-311 dvd/receiver/home theater
Had the hardest time finding a code for this old TV.
Posting now so that others can find this solution.
White-Westinghouse
Modle: WTV-11901
Comcast Remote Control Code 0451
Dec 22, 2007 | Zenith ZEN310 Universal Remote Control
Televison & Video Logo
522 people viewed this question
Top Televison & Video Experts
Electro Med Services...
