The dryer dries just fine. However it will not stop at the end of a cycle. It will tick on and advance to the next cycle over and over. The only place on the dial that it will stop and remain stopped is at th 1 oclock position at the beginning of the time dry cycle. I have to manually turn the dial to that section and then it will be permanently stopped.
  • debcougar Nov 17, 2009
    The dryer dries just fine. However it will not stop at the end of a cycle. It will tick on and advance to the next cycle over and over. The only place on the dial that it will stop and remain stopped is at th 1 oclock position at the beginning of the time dry cycle. I have to manually turn the dial to that section and then it will be permanently stopped. If I open the door, dryer will stop and if I close door dryer will start running.
    President:
  • 1,515 Answers
Hello, sounds to me that if you can manually move your timer to continue, and all works fine except this. I would say that the problem is in the timer contacts itself. Not knowing the sequence of operation on this particular dryer, I would highly suggest contacting the maker of this dryer with the model, serial, and product numbers and relay this information to them. I will look for a link for you, please stand by while I search: After reading over the problem, you have not given me a name or other info. Can you please get this for me so that you and I can work on a solution for you? Thank you, Sincerely, Shastalaker7
Posted on Nov 17, 2009
    Brigadier General:
  • 3,513 Answers
The timer is in charge of stopping the machine. The timer seems to be broken.To verify this Open the dryer door while its running and see if it goes off.
Then close the dryer door and see if it starts by itself without you pushing the start button.Its likely your push-to-start switch is bad.
Thanks for contacting Fixya.com
Posted on Nov 16, 2009
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
Dec 17, 2014 | Roper Dryers
Whirlpool dryer shuts off at the end of cycle, but timer continues to tick. It ticks through the next cycle and stops ticking at that cycles off?
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it.
Oct 01, 2013 | Whirlpool Dryers
DWSR483EAWW GE Dryer doesn't turn off when set to "Optimum Dry"
Does the timer advance to the end or does it stop advancing in the middle of the cycle?
If the unit does advance to the end on timed but it won't advance on auto, that means your cycling thermostat isn't triggering. First, make sure your vent is cleaned and the best way to do that is just run a cycle without the vent hose connected to the back of the dryer to see if things change. If your dryer still won't dry properly, then the cycling thermostat will need to be replaced because it's not cycling properly.
Try it on the timed cycle. If it doesn't advance, then you have a bad timer and the timer will need to be replaced.
The cycling thermostat is mounted to the front of the blower wheel housing.
Here is the timer if it is found bad.
Here is the cycling thermostat if it is bad.
Keep me posted!
Nov 30, 2012 | Dryers
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
I have a whirlpool dryer, model number lgt6634dq0. The timmer does not stop after the drying cycle has ended. My guest it might be the timer. After the dryer has finished it's cycle I can hear the timer...
HI. The timer will be the culprit here. The timer motor is damaged, and the cogs seem to be worn, as well. I recommend replacing this failed timer mechanism. Once replaced, the unit will operate correctly.
Dec 03, 2009 | Whirlpool Dryers
The Timer Knob on my Maytag Dryer does not move. The drying just goes on and on unless I notice and stop the dryer.
While the dryer is turning slowly advance the timer knob to the end of the cycle. The dryer should stop. It sounds as if the timer motor has died or is not being powered for some reason and is not advancing the timer.
Nov 12, 2009 | Maytag Clothes Dryer Almond Timer Knob...
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore 11070702990 Gas Dryer - Timer does not work
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
MAYTAG SDE3606AZW ELECTRIC DRYER
Does the dryer dry fine? If your dryer is taking too long too dry you might have a venting obstruction that is not allowing the dryer too sense that the clothes are dry so the timer won't advance. Try disconnecting the vent from the back of the dryer and dry a load unvented and see if the timer advances.
Jun 11, 2008 | Maytag SDE3606A Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
