Question about Duracraft DS-1600 Fan
Need some replacement parts
I need help finding replacement clips that hold the cover on.
  • 66 Answers
Go to the hardware store and ask for the kind of clip that you nees
Posted on Nov 16, 2009
My dog knocked a wood burner into the front cover of a fashion mate 69 stitch computerized machine is there a way to replace the front cover?
Probably. However, the first issue is finding a replacement cover--may have to find a used donor part for that. Second issue is actually getting the old cover off and the new cover on without cracking or breaking anything, ie the plastic clips that hold the cover in place.
Apr 30, 2017 | Sewing Machines
How to replace front glass on this unit
I need the model of your phone to find you a guide. A guide may not have been made for that device, but If not, I can find you a guide where the build and dissembly are identical. (Standard breakdown . remove battery cover. Battery, sim card, SD card, remove screws plastic cover. Use a guitar pick/opening tool to run along the seam to split plastic case. From here. Remove any metal shields (if any) to disconnect all connectors. Such as LCD cameras mic , vol buttons etc. Once freed of connectors remove screws holding logic board down. From here you should be holding a front "clip" just glass. LCD. And digitizer. Depending on your part.if its a complete front clip. The just follow steps in reverse on new front clip. If it's just the glass. You will need a hair dryer or heat gun to heat up glass and make adhesive loose enough to separate the glass from the frame. Once separated . follow steps in reverse. Take lots of pics during disassemble to remember location and order )
Sep 07, 2015 | Blue BLU Studio 5.5 D610A JB 4.2 Android...
Battery clips
you have to remove the circuit board from the case. There is a rod that holds the clip in. You have to remove a little rubber cover that keeps the rod from coming out.
You need the part number : PMDN4022AR
Mar 21, 2012 | Motorola Mag One BPR40 Two Way Radio
Headlight bulb replacement on renault modus
Replacing a dipped head light bulb on a Renault Modus.
Having recently purchased a 2008 Modus with the passenger side dipped beam head light bulb not working. Concerned that posts on this matter talked about removing several body parts or a costly visit to the Renault dealer.
It's a simple 10 minute job. It is a little tricky with limited access and restricted view. However - its as simlpe as - remove circular cover from rear of bulb holder - remove the clip on connecter and push to side. You need to pull the wire clip above the bulb slightly to the side from its holding and it flips down and out of the way Be careful not to detach the clip from its holding points below the bulb - it's extra hassle to put back in.
You can now remove the old bulb - replace with the new bulb. Make sure its sitting correctly in housing. Re attach the clip to its holding point above the bulb. Replace the connector.Replace the circular cover to the rear of the bulb holder.
It takes 10 minutes - cost me under five pounds for the replacement bulb. Hope this helps.
Feb 05, 2012 | Renault Modus Cars & Trucks
Hello there, I have a Bosch Logixx dishwasher which I purchased just over 2 years ago. My upper dishwasher tray is not fitting properly into the hose pipe holes on the inside of the back wall of the...
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Regards,
BElectric
Apr 13, 2011 | Bosch 24 in. SGS69L02 Logixx Built-in...
Can't remove top cover
HI There,
there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to un-clip these clips on both the left and right sides, then remove the top motor housing from the machine.
I have written a detailed instruction on how to fix the turbine inside that controls the brushes. You may find this helpful:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
If you found this to be helpful, please be kind and leave some feedback for the repair. This is what keeps Fixya repair professionals like myself continue posting free repair instructions rather then using the premium answers that users pay to get answers. This is really greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
Apr 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Faulty Coolant Temperature Sensor...how do I replace?
the ect sensor is on the right side of the front of the engine compartment. Need to pull both engine cover off to change. the part is about $15.00. Locate sensor. Pull the plastic clip holding the sensor and pull sensor straight out. Install new one (should be green color with 4 blades) and slip clip back in to hold sensor. job takes about 10 min or so.
Mar 11, 2010 | 2004 Volkswagen Jetta
Replacing headlight bulb ford focus
Most of this solution for changing a headlamp on a ford focus sedan is taken from solution 2's writeup, accept with a few more details that should help changing the bulb assembly for the novice. Pop the hood. At the front of the car, look to the back of the headlight assembly. There will be a plastic cover on the back. On some models, you need to unscrew the plastic cap; on others, it just pops or screws off. Remove the plastic cover and then take note of the orientation of the three prong connector on the back of the bulb assembly. This is important because the replacement bulb assembly is going to have to be positioned in the same manner. By noting the orientation before taking out the old assembly, it will be easier to orient the replacement bulb assembly after removal.
There is a small retaining clip that surrounds and holds the bulb in place. Removing the clip can be tricky. On my 2003 Ford Focus sedan, there is a special place to push and release the clip that is above the bulb - perhaps further above than you might think. Push the release clip and it will release the retaining clip from the bulb assembly. Gently pull the retaining clip down and out of the way of the bulb assembly. Pull the original bulb straight out. Remove the three prong connector from the bulb assembly. Connect the three prong connector to the replacement bulb and then orient the three prong connector as the original and push bulb assembly straight back into place. Jiggle the assembly slightly to seat it into the correct position in the headlamp housing and replace the retaining clip to hold the bulb in place. Replace the plastic cover on the back of the headlamp and replacement is complete.
No tools. 10 minutes.
Dec 16, 2009 | 2001 Ford Focus
Need to know where to buy window clips?
You can get these clips at GMPartsDirect.com.They are parts # 15938039 & 15938040.These are the updated part #'s.Just bought them online (4/02/09). They cost about $57 for both clips.Hope this helps.Good luck!
Mar 31, 2009 | 2002 Buick Rendezvous
1999 Accord front bumper cover
I do this for a living and I think I can help you.
The bumpers are available for around 35.00 wholesale, the paint is waht is expensive, Installation is a breeze. Bolts on each side and clips to wheel skirts, Headlights may need to be removed I can't remember, also under the car is a shield that attaches to the cover. It will come right off after that. I think a couple of clips under the hood holding it to the core support, I do so many of these it is hard to remember exactly how each one is attached, but just installed one on and acura rsx,. Hope this helps you!
Dec 26, 2008 | 1999 Honda Accord
Dryers Logo
344 people viewed this question
Top Duracraft Dryers Experts
richie46
Gil Shultz
Are you a Duracraft Dryer Expert? Answer questions, earn points and help others
