Question about Canon PIXMA MP160 All-In-One InkJet Printer
Paper Jams When running paper throught the feed, the bottem right side of the page is catching and jamming the paper. It seesm as though the left side is not catching at all. I have reset the printer. Moved locations (off balance?), tried manually assisting the paper through. Nothing! What can I do?
  • 233 Answers
Most likely there is paper or something stuck in that corner
use a flash-light an carefully inspect the area
hope this helps
thanks for rating
Posted on Jan 09, 2008
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
Paper pulls to right side and then jams it all started when paper jam i pulled it out and ever since then when loading paper it pulls to the right and then jams
Try running a good sized thickness paper thru it to clear out the cutters.
Sometimes when they jam some residual paper is left in the space between the cutter wheels and causes the paper to feed askew...
I use the cover from old phone books.
Sep 29, 2011 | Office Equipment & Supplies
Paper jam door - I cannot open this no my HP 8250.
Turn off the printer, then unplug it from the power source. Clear the
printer of any paper that may be obstructing the paper path. Remove the rearaccess door. Gently remove the jammed paper from the printer, then replace therear access door.
Remove the rear access door to clear paper jams.If you cannot remove all jammed paper from the rear area of the printer, tryremoving paper jammed in the middle of the printer by opening the paper jamdoor located inside the top cover.
Open the paper jam door to clear paper jams in the middle of the printer.Plug the printer back in and turn it on.
In case of any doubt go to the following link and act accordingly
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00386753&lc=en&dlc=tr&cc=us&product=443024
Sep 25, 2011 | HP Photosmart 8250 InkJet Printer
Paper jams every sheet. Checked the paper weight, made sure it was faned edges and not rolled. Catches on the left side as it rools in from the drawer. What can I do to fix it. I have used it many...
Marie, there is something stuck between the paper tray and the transport section of the copier. Probably a small piece of paper. try to push a piece of paper up from the tray to the rest of the machine to push this obstructing paper out of the paper path. Also try using the handfeed section on the right hand side of the machine by folding down the tray and putting paper in it. You may have to choose this "manual" feed tray on the operation panel. Good luck !
Feb 20, 2011 | Canon imageCLASS D860 All-In-One Laser...
IP3500 keeps misfeeding paper, it takes it from the right hand side (looking at it) and jams everytime. It is out of warranty but has had very little use, please help!!
possibly that a foreign object, ( label, scrap of paer), has fallen down inside on the left hand side, and it not letting the feed roller catch the paper, the right roller gets it and then it jams. You can get a torch and have a look where the paper goes in to see if this is the case. Dismantling a printer is not an easy job, and it would probably be cheaper on ink to buy a new one.
Sep 17, 2010 | Canon PIXMA iP3500 Printer
My printer will not feed the paper properly. It
There must be a jam on the left side then. Open and look inside for the paper issue
Jun 16, 2010 | Lexmark JetPrinter Z11 InkJet Color...
Pper jams
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Toshiba estudio 200 keeps having false paper jams where are paper sensors located?
its not the paper sensors you need to get to its the feed rollers,which will be above the paper tray near either the left or right side of machine. clean those with glass cleaner. if they appear smooth in any way they should be replaced, keep old ones to compare. what you are referring to as false jams we in the copier world call the "ghost jams"
May 08, 2009 | Toshiba Estudio 200L Copier
Paper jamed
Sounds like the fuser is causing the jam. Anything from a dislocated pic finger to other paper debry can be causing these types of jams.
If you open the back door, will the page exit the printer fine of does it still jam?
If it still jams the fuser is definatly the problem. If it dosen't, then it might be the delivery assembly causing the jam.
You might be able to see where the jam is happening if you print something and watch it though the back to see where the paper catches and jams.
Nov 19, 2008 | Brother HL-2040 Laser Printer
My paper keeps jamming
Clearing paper jams Paper jams can occur for a variety of reasons but are usually paper related. Follow the steps below to clear the paper jam:
  1. Turn off the all-in-one and unplug the power cord. With the power off, the paper feed rollers will turn.
  2. Open the rear access door of the all-in-one by pressing in on the left side of the access door and then pulling it toward you. NOTE: All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems. Figure 1: Rear access door c00101861.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
    • If under warranty, contact HP to obtain a replacement part.
    • Click How to buy on this page to order replacement parts.
  3. From the rear access door opening, gently pull the jammed paper free.
  4. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray. Do not continue to push the paper in after some resistance is felt. If the paper is pushed in too far, more than one page will feed into the all-in-one at a time.
  5. Reattach the rear access door by inserting the two pins on the right of the door into the holes for them (as shown in Figure 3 below) and then pressing in gently but firmly on the left side. Figure 2: Inserting the rear access door guide pins into the holes c00099183.bmp
  6. Reconnect the power cord to the unit and turn the unit on.
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
