Question about Google Chrome
How to chrome and what is the chemical? - Google Chrome
    President:
  • 2,017 Answers
Google chrome is the browser like internet explorer and mozilla firefox.
Posted on Nov 16, 2009
Kitchen sink has tiny cracks. Why are cracks appear and how to fix this sink
Hi there it might be that you have used a harsh abrasive chemical to clean the sink and there's a residue remaining from it eating into the surface causing theses cracks to. Appear
Or the chrome enamel surface. Is breaking down try using a 're chroming agent like silvo
Jul 03, 2016 | Dishwashers
Nordictrack cxt 910- which lubricant should I use?
Hi Linda- "Teflon" is a DuPont chemical brand name. I checked their website and found the following link for availability.
Happy exercising!
http://www2.dupont.com/Consumer_Lubricants/en_US/assets/downloads/DuPont_Teflon_Lubricants_and_Greases_Product_Availability.pdf
Apr 01, 2014 | Exercise & Fitness
I'm cleaning my rim and for some reason it is turning a gold color. What could be the reason for this?
Can be several reasons. Some types of plating or covering is the top finish of the wheel, but the base metal is a different color and not pretty.
I have seen chromed wheels bleed down to the core behind the lead wheel weights. Those left a bronze mark in the same place and outline of the lead weights.
Now there are different procedures in producing a finish on metal. Some use an acid bath and different chemicals produce colors in metal. Sounds like the wheel you have could have been surface etched and now the top finish is rubbed down below its finish. Some makers use a clear coat to maintain the finish longer.
You should contact the Car company who made your wheel for ideas about refinishing them. Now there are some excellent spray paints for coating wheels and the cost is minimal and some use spray cans and others need air compressor spray guns. Likewise some need an adhesive base coat and some need a protective clear coat. Its all about compatible layers of coatings.
My personal experience, for instance, on my 83 GM Pontiac Aluminum rims was to use the finest grade steel wool and remove the old chipped surface by hand rubbing to clean metal. Then using Mothers products to hand buff to a brighter finish and then thoroughly remove all traces of chemicals with an alcohol wash. The top coat was a spraycan application of specific "Wheelcoat" clearcoat.
Please rate my info.
Jan 18, 2013 | Cars & Trucks
I put chrome tips on my 2006 chevy 6.6 diesel. After a week they turned blue and the chrome flaked off. The tips look like **** now. What happened?
Chrome does not like diesels the exhuast get too hot and turn chrome blue and the chemicals in the exhuast will eat chrome. The best thing to use if you want chrome is to go polished stainless steel. this is a harder metal, will not blue as easy and will not rust
Jun 22, 2009 | Chevrolet Silverado 3500HD Cars & Trucks
Decalcifying method
There is an auto button on your machine the double ellipse button, hold down for 5 seconds display will read descale.
Safe Descaling method
1- Always use the right descaling products.
Descaling chemicals purchased from supermarkets may not be suitable for the machine. Use of Vinegar is prohibited by manufacturers. Please read the operating manual. Do not use Cafiza, Cleancaf or PuroCaff. These are coffee cleaners recommended for back flushing coffee machines.
2- Always dissolve the Descaling chemical in a container and pour into the water tank. Never add directly into the water tank. Crystals of chemical will slide into the filter & pump and block the water hose and restrict flow of water.
3- Do not pour solution when the tank it is on the machine. In fully automatic machines, the bean hopper is next to the water tank. The solution / water can accidentally get into the bean hopper and cause serious damage to the grinder.
4- Espresso machines have separate water passage for Hot water from steam pipe and espresso dispensing. Flush the solution from both sides, alternatively. Turn machine on, flush one cup from steam pipe and turn machine off. After a pause of 3 to 5 minutes turn machine on and make one large espresso (4-oz.). Repeat this process until all of the solution in the tank is used up.
This method is best both for semi-automatic & fully automatic espresso machines.
Using Electronic programmed method does only half the job as it flushes descaling solution only through the steam pipe. The machine must be flushed with solution from espresso side as well. Automatic descaling method should be completed by making 6 espresso with or without coffee (using pre-ground cycle when available).
5- Rinse the water tank and fill with fresh clean water. Repeat the rinsing process alternatively until four tanks of water is used up to flush the chemical out.
Caution: Do not leave the machine before completing the rinsing with clean water. The solution left inside will corrode & tarnish metallic surface.
Do not leave Chrome plated objects submerged in descaling solution for more than 10 seconds. The chrome will dissolve and leave the item permanently corroded and black.
Jun 07, 2009 | Gaggia Titanium Espresso Machine
Removing chrome plastic hubcaps 2006 jeep liberty
If you can get it where you are - try Autoglym Tar and Resin remover.
Jun 06, 2009 | 2006 Jeep Liberty
Lines are clogged and the coffee is not coming
Use Scalekleen or other citric acid.
1-
machines.
when available).
metallic surface.
Jun 05, 2009 | Saeco VIA Venezia
Handle stuck; How descale w/o ruining chrome finish
WD-40 will not harm the chrome but it you have liquid wrench, it would be better lubricant as WD 40 chemicals are actually a cleaner.
A descaler you need to be careful here. Lime-away or CLR is a popular choice but you need to read the label on chome products.
Jan 25, 2009 | American Standard Collection 4241.002...
Mud stain
depends on what material is stained.. Aluminium stains can be very tricky to get clean if not impossible...some cleaners will also cause a orange/reddish stain wich will not come out unless you use some harsh chemicals to get them out. problem is it's hard to get to those chemicals. IF you happen to have a truck wash nearby where they wash the big trucks (18 wheelers)take your parts there and tell them to use some brightener on it it's a chemical that really cleans aluminium.it may cost you a little bit of money but that stuff really works and i haven't been able to find that stuff for private sale anywhere. the number 2 reasons for stains on the bike are : 1) waiting to long to wash the bike some types of sand/mud especially the red dirt we have down south here will stain a bike if you leave it on the bike not only that it dries as hard as concrete and is very difficult to remove , so was your bike ASAP. 2) washing chemicals. Some chemicals / soaps when they are left too long on aluminium will leave stains as it reacts with the aluminium , these stains are almost impossible to get out. ,,,
Nov 10, 2008 | 2002 Husaberg FE 650s Dirt Tracker Chrome...
Google Chrome Logo
22 people viewed this question
Top Google Computers & Internet Experts
Robet
Robet
Sunil Pratap Singh
Sunil Pratap Singh
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
