Question about Lexmark Z640 InkJet Printer
Drags the paper in all uneven.
I have not had the printer very long, if I want to print anything it drags the paper in all uneven, almost like only one side is working the other is not, and I cant seem to rectify it, where am i going wrong. It never used to do this.
  • 233 Answers
Clean the rollers with a little rubbing alcohol.
hope this helps
Posted on Jan 09, 2008
Paper drags at the end of printing and smears the end of picture
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 3300 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Jan 15, 2012 | Lexmark OfficeCenter X3350 All-in-One...
Paper drags to the right and won't print--worked yesterday!
Sounds like you might have a small piece of paper stuck in the paper path that is causing it to feed incorrectly. Check the paper path.
Apr 01, 2011 | Dell Inkjet 720 Printer
Extra paper feeds and jams after each print. One copy prints and then the printer drags the next sheet down halfway and jams.
The feeder assembly is not timed right, it happens when you pull out a jam. It may have a broken spindle or gear, I would take it to a shop to figure out.
Aug 11, 2009 | Canon PIXMA MX310 All-In-One Printer
2 sided printing. Printer drags more than one sheet of paper thru at a time
make sure you fan the paper before putting into the tray. failing that try a different weight of paper.
thx
Aug 01, 2009 | HP Office Equipment & Supplies
The printer drags the blank paper to the right side of machines then jams
try to rearrange the paper on the tray or add some paper to it..maybe the paper pick failed to pick them on time ..that'a why it give a jammed error..
May 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Roller drags several sheets of paper and results in a paper jam
Open your printer and release jam paper then solve problem.
Apr 09, 2009 | Lexmark E322 Laser Printer
Printing Problems
That is known as paper skew. It normally comes from A. Worn or dirty rollers either in or just past the paper tray.
B. The paper tray itself. C a spring off a roller not allowing even pressure on the paper, or D, the registration clutch which is responsible for stalling the paper long enough to square it in the machine.
For some reason the paper is twisting from uneven drive to the right side of your print as seen in the photo. Could even be a slight obstruction aka a piece of a label or tape that somehow is in the paper path causing the paper to drag in that area.
Normally skewing ( twisting ) of the paper it pretty easy to cure. I am suspecting with a 5 year old machine, some slick rollers first, then a spring/pressure problem on some roller.
Let me know, We can fix this one.
Jun 11, 2008 | Xerox Phaser 8200 Laser Printer
I455 Canon printer
your problem is due to gummed ink jets.. take out your ink cartriage and clean the bottom of it. make sure you avoid cotton or anything that would leave lint behind. also clean your shuttle. some shuttles you can pivot off from the track to clean and others you just can clean the tracks. make sure there is no ink gummed up on the tracks or the bottom of your cartriage
Mar 13, 2008 | Canon i455 InkJet Photo Printer
Dell --924 copier
clean feed in roller with rubbing alcohol on a micrfiber cloth if there is white reside on rollers you just have a traction problem
also make sure no torn paper is in the paper feed area
Dec 19, 2007 | Dell 924 All-in-One InkJet Printer
Lexmark Z640 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
