Question about Acer Computers & Internet
I am trying to connect to a wireless adaptor. I am getting a code 12...
  • 150 Answers
Note For help with device problems in Windows Vista, visit the following Microsoft Web site to automatically diagnose and repair problems with devices. For example, visit the following site when the device manager does not detect your hardware, audio, USB, or other devices or when your devices are disabled or not working. http://support.microsoft.com/gp/hardware_device_problems (http://support.microsoft.com/gp/hardware_device_problems)
Posted on Nov 16, 2009
I can't connect to the wireless Internet despite
Borrow other wireless adaptor, then plug it to your desktop. Try to connect ...but U must install the adaptor driver too. If it works, that means your internal adaptor is out of work.
Jan 01, 2012 | Acer Computers & Internet
Wireless Network Adapter Xbox 360 (SKWIFIX360): My wireless adaptor on my xbox 360 won't connect t...
1) Reset the router then the xbox.
2) If it still does not work, Change the security code for your wireless on your router. Then connect using that security code on your xbox.
Apr 28, 2010 | Microsoft Computers & Internet
Get ''pending'' for ever when trying to connect to wireless AP. Log says can't set wireless frequency - operation not supported and then DHCPDISCOVER never gets an answer. If I use static IP simply get...
I had a similar problem. Hit "Fn"+"F2" to cycle the wireless off then on again. Allow about 30-60 seconds to get IP and DNS info from the access point.
Then, using the network adaptor icon in the utility bar (on the bottom right), right click, select "all network connections". Click each network adaptor and from the "Connection Tab" Disconnect each adaptor. Then restart the wireless adaptor with the "Connect" from the "Connection Tab".
I'm assuming that there are no funny settings in the Properties which are preconfiguring the adaptor for a previous connection. If so remove any present values. Leave the connection set as DHCP as this is teh most common way that adaptors will get their settings from teh access point your attempting to connect to. Cheers.
Jul 10, 2009 | ASUS Eee PC 701SD
I have a Belkin Wireless adaptor and a wireless router. The netgear adaptor I had before on my desktop got borken so I replaced with a Belkin adaptor. The new Belkin adaptor is not recognizing the wireless...
Hi, did you provide the network key/password when you setup the wireless conection on your computer? Is it detecting your wireless router (you should see your SSID or network name) when you click on your wireless icon (in the taskbar) and chose "show wireless connections". If you can acess to your router via it's configuration page(type the router's default IP address in your browser) you can go check the settings and change the key/passphrase if you dont remember it. If all of this is not working, you can also start from stratch. Reset the router to factory settings (check your manual) then reconfigure it the way you want, put the new infos in your wireless network connections properties and try again. let me know with more specific details if you still cant do it
Jun 08, 2009 | Belkin Wireless Desktop (F5D7000FR)...
Wii USB Adaptor
the easiest thing to do is to get an usb wireless adapter for about 30 bucks , connect it to your pc or laptop , set it as an access point , then just use the built in wifi on the wii , to get on the net, hopes this works , did for me
Oct 30, 2008 | Computers & Internet
Wireless never worked in Acer Aspire 3000 notebook ..help!
you have to install the wireless drivers, check it on cd
Oct 15, 2008 | Acer Aspire 3000 Notebook
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
No wifi
You need to get a wireless adaptor your laptop did not come with wireless built in. You can get a USB adaptor or a PCMCIA adaptor. Either will work but the pcmcia adaptor will be a little faster
Have a look here
http://www.google.com/products?hl=en&q=pcmcia+wireless+card&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
Hope that helps
Aug 25, 2008 | Compaq Presario Notebook
How do i change the "channel" of my wireless internet?
The belkin USB adaptor does not appear to have a channel selection option. Like most WiFi adaptors it scans and connects to the available networks assuming the security matches.
What you need to do is change the BROADCAST channel in your router or access point. If you are unsure how to do this I suggest you post the make/model and I'll try to assist you.
Ensure you use 1-11 as this adaptor does not support ch 12 or 13 wheras some routers do.
You may find the NETSTUMBLER prorgam useful in finding a free channel to use.
Jul 15, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
2wire wireless adaptors
I have installed 2 2wire adapters with no problem. When using config software utility, don't select gateway (if using only adapter), then continue until sets up. No serial # required unless using a gateway, which is not needed to connect to wireless.
Oct 15, 2007 | 2wire (1000-000005-002) 802.11g/b Wireless...
Computers & Internet Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
