Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher won't drain
Dishwasher will not drain. already cleaned out line.
    President:
  • 4,402 Answers
The pump would be the first culprit to check. I believe that the pump in this model is electric and not driven by a pulley, so switching out should be easy. First you want to verify that you have power going to the pump while in the drain cycle. If you have power going to it and it's not pumping water out you can be pretty sure that is the problem. The front panel can be removed by removing the two screws at the bottom and lifting out. Now you can get a good look at the motor and pump.
Posted on Jan 09, 2008
Belling dishwasher won't empty. I have cleaned the water filter and the machine worked fine this evening it won't empty?
Search Results
    Belling won t drain Dishwashers Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > won t drain > Dishwashers
    Belling dishwashers won t drain related questions and answers. Ask your Belling questions. Get free help from dishwasher experts.
    How to fix a dishwasher that won't drain - Dishwashers ...
    www.which.co.uk/.../dishwashers/.../how-to-fix-a-dishwasher-tha...
    Which?A dishwasher that doesn't drain can cause concern in your kitchen, but you may not ... Check out our video to see how to repair a dishwasher that won't drain.
    i have belling dishwaher which is not emptying e1 showing as
    www.justanswer.co.uk > Appliance
    OK, so it fills and starts the cycle and then won't drain and this error will flash ... is ... the washing machine which is at the side of the dishwasher has been giving ...
    How to Fix a Dishwasher That Will Not Drain - YouTube
    ? 2:13
    https://www.youtube.com/watch?v=nr6tIO5iNSc
Feb 08, 2016 | Belling 24 in. IDW603 Built-in Dishwasher
Dishlex dishwasher won't complete a cycle. Number 60 shows up and a small flashing line. ??????
Drain pump is blocked. .If you are good with tools you can clean it yourself. Let me know
Mar 28, 2013 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
My frigidaire professional dishwasher won't drain
In the bottom of the unit, do you notice clean or dirty water? Do you have the unit connected in the same drain line as a garbage disposal?
Aug 31, 2012 | Frigidaire Dishwashers
Water won't drain
Hello & Welcome to FixYa
As the water did not drain completely then check the drain hose & drain pump filter located inside the front bottom access panel for any clogs/obstructions, if you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher won't drain. water remains in the base of dishwasher
clean out the sump and all the drain lines to the sink or disposer however its hooked to the drain
Sep 11, 2011 | Dishwashers
Slow or no drain of water. cleaned out sump covers and ran drain cleaner thru cycle. looking for possible secondary filter.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 27, 2011 | Hotpoint Dishwashers
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hope it helps...
Jun 23, 2011 | Dishwashers
My dishwasher won't pump out. I've cleaned filter and cleared line. still won't pump
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
May 09, 2011 | Maytag Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
61 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
