Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
The steam do not get hot it get warm athe water
The steam do not get hot it get warm athe water run in the pad leave the floow wet my name is sarah brown i live in miami fl i thing i have inc, on my unit. the euro-pro steam do not steam at all sarah401032@yahoo..come /? sarah .
  • Euro-Pro Master
  • 43,501 Answers
Sarah, the unit is no good...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
I have a scunci ss 1000 hand held steamer cleaner. Its been used and given to me from a friend. The steam comes out the trouble is the steam is not hot, just luke warm. how can I fix it myself.
Try descaling it with CLR. Add CLR and water, turn it on but not fully to produce steam, just get it hot. Leave it for an hour. Empty that out and out some more in. Get this up to steam for 10 minutes, switch off, leave it for an hour and empty it. Fill and rinse out twice. Fill with water and see if it is fixed.
Nov 09, 2015 | Scunci SS1000 Handheld Steam Cleaner
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
My steam glide russell hobs iron pours out water when used I have burnt my self a few time. It also leave the garment very wet.
Many persons put too much water in a steam iron.
Make sure that you do not fill it all the way to the brim.
Try using less water in the tank.
This may also solve your wetness problem.
Aug 29, 2011 | Vacuums
I got power, lite on, tank is warm, but No Steam to mop pad, just a little water to wet the pad. Whats wrong?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Dec 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Makes steam. Leaks where pad goes into pad attachment. Pad doesn't get hot steam...just water but the pad doesn't really get wet but the floor does.
heatman101
Oct 10, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I do not know how to operate are hoover steam vac
pull out water container, fill the inner "bag" with hot water and cleaning solution, (the dirty water goes outside of the "bag" inside of the container. First run, squeese trigger to wet area, leet sit for a minute or two the go back over it until you feel it has picked up enough of the water. It will still feel wet, but as long as it was not picking up any water when passing over the area, thats all you can do. run fans and open a window.
Jan 24, 2010 | Hoover F5886-900 Steam Vacuum
I have the standard steam mop. It rarely puts out
its under warranty contact bissell the unit will be replaced by a local service center if you have any problem let me know
Dec 10, 2009 | Vacuums
I have the S model and I have only used time,
Pads do not get wet...just a bit damp...
heatman101
Nov 16, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
144 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
