Help Finding The Best CPU For P4SD-VX Motherboard.
Hey there, i have a Sony Vaio model : PCV-RZ31G. The motherboard is a P4SD Vx and the bus clock is 200mgz. I need help with finding the best processor or at least finding out what cpu my motherboard can handle. Any help would be great.
  • kevin_liesko Nov 16, 2009
    It seems to me by using CPU-Z That my clock multiplyer is X 13.0 It says under the CPU tab that the core voltage is running at around 2.6V. and not sure if its relevent but under the SPD tab it says the voltage is 2.5 V for both JEDEC#1 and JEDEC#2. And its a 478 socket
  • joecoolvette
    joecoolvette May 11, 2010
    If your Sony is working, and internet capable, I'd like to suggest that you download the tiny, free program CPU-Z from CPUID.com This should give detailed specifications on your motherboard, (Mainboard) Need to know what the clock multiplier is, and the voltage for the processor. Also, is it using the LGA 775 processor socket, or the Socket 478? (If you have any problems trying to download CPU-Z, let me know)
  • 5,660 Answers
Brilliant, I commend you! I've posted using the simple CPU-Z program to several people on here, and they just don't seem to get it!
Sony doesn't release detailed info on their motherboards, for the most part. Just the usual generic info.
2.6 Volts?
Open CPU-Z again. CPU tab.
Let's see if you have this processor.
Name: Pentium 4 HT 2.6C
Code Name: Northwood
Package: Socket 478
Technology: 130nm
Core Speed: 2600.0MHz (Fluctuates when the computer is running)
Multiplier: 13X (Fluctuates when the computer is running. When the Core Speed fluctuates enough, the multiplier changes to match)
Bus Speed: 200.0MHz
Rated FSB: 800.0MHz
Voltage: 1.475 to 1.525 V (Fluctuates)
Click on the Mainboard tab.
Is the motherboard chipset Intel 865PE?
[Chipset: Intel i865PE
Southbridge: ICH5 or ICH5R
Motherboard made by Asus?
It may not have an Auto CPU feature in BIOS Setup then. Means you cannot just put any old processor in there. Have you been into your BIOS Setup yet?
SPD stands for Serial Presence Detect. This is used by BIOS to automatically detect what ram memory is being used, and the ram memory timings.
JEDEC was Joint Electron Device Engineering Council/s. Changed to JEDEC Solid State Technology Association.
One of the things they have done is to set standards for Ram Memory.
Voltages used and ram timings.
JEDEC 1 is the ram memory module, in Slot 1 on your computer.
(May state DIMM 1 on the motherboard)
JEDEC 2 is the ram memory module, (Stick) in Slot 2.
JEDEC set the voltage standard for DDR Sdram ram memory, at 2.5 Volts. Your computer has DDR Sdram ram memory in it.
The default voltage setting from the factory will be 2.5 volts for your computer.
Posted on Nov 16, 2009
Network conexion
You can download the LAN and device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 22, 2013 | ASUS Computers & Internet
Ptgd-vx drivers
Download DriverPack Solution 12.3 Full and the run it. It will scan your system and install all driver which will be missing. Its complete pack of all motherboard and laptop drivers.
Jun 08, 2012 | Sony Computers & Internet
I have a sony PCV-4Z32G. It stopped working. The motherboard is a P4SD-VX. It appears that the northbridge has become disconnected. Can this be reattached?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 19, 2011 | ASUS P4SDX Motherboard
Would like to replace cpu in sony vaio rs402
From the research that I have done, you should be able to upgrade with no problem. I would suggest upgrading your RAM to make things run smoother. Good Luck
C2S
Apr 04, 2009 | Sony VAIO RS402 (PCV-RS402) PC Desktop
Sony vaio pcg fx301 clock speed
You'd have to go into the bios and change the CPU speed or the BUS speed. I wouldn't recommend OCing a laptop, though, as they tend to get hot enough w/o it.
May 16, 2008 | Sony Vaio PCG-FXA Series AMD (A8058677A)...
Sony VAIO PCV-RS720G - Hard Drive
kept trying Asus for your board details but their site was down,and also need to know socket type, but you may need to upgrade your bios to support large drives. You can find the motherboard support site here:- http://support.asus.com/download/download.aspx?SLanguage=en-us
May 08, 2007 | Sony VAIO PCV-RS720G (027242658103) PC...
403 people viewed this question
k24674
jasbo
jasbo
