I have had my Zenith Clock Radio/CD/Am/FM/TV/Weather Bands #Z2020 for several years now and the CD part no longer works. What can I do to get it fixed?
SOURCE: AUDIOVOX CDA 100 AM/FM/CD setting clock
SETTING THE CLOCK - AUDIOVOX CDA-100
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Posted on Jan 18, 2008
welcomejee
  • 10594 Answers
SOURCE: Need user manuel
It would be nice if you post model number of Sony FM / AM clock radio to get user manual as Sony have several models.
Posted on Sep 17, 2008
  • 71 Answers
SOURCE: Replaced radio with one from same model year. Displays Err 01.
this generally means the laser is either dirty or the cd player is shot, err 01 is a disc reading problem. Try cleaning lens with cleaning disc first if this does not help i would replace the unit with another. i would recommend replacing it with a cheap aftermarket stereo.
Posted on Nov 27, 2008
SOURCE: No directions for Emerson S.A.M.E. weather research radio
We are all set. We found the directions. Thank you!
Posted on Dec 12, 2008
Fips codes
FIPS are 5 digit codes..the 1st two codes are for the state: the last three are for the county. This link allows you to find both state and county for your area: http://www.epa.gov/enviro/html/codes/state.html
Apr 21, 2013 | Midland Radio Midland WR11 Desktop Alarm...
TV reception band no longer works
all analogue signals going out means EVERY analogue signal is gone in the TV band. these are now apparently assigned to emergency services in some states.
Jun 14, 2009 | Audio Players & Recorders
No sound
If you are getting AM sound, but not FM, its because the headphones you are using are shielded for interference. This shielding is what is causing you not to be able to pickup FM, as the headphone wires are what is used as an FM antenna for the unit. Try using a CHEAPER set of headphones (Yes, I said cheaper). Cheaper headphones usually don't have the shielding. Usually these types of headphones have both wires for the headphones bound together as one wire.
Apr 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Sony ICF-CD855V clock radio no power
Transformer wire that connected to one of the AC terminals was broken. Soldered a jumper wire between the terminal and the transformer. The most difficult part was finding a tool to remove the 3 triangle headed screws from the power supply, ended up making my own tool.
Dec 29, 2008 | Harman Kardon Sony ICF-CD855V...
Dec 11, 2008 | Emerson Smartset Clock Radio
Need user manuel
Sep 17, 2008 | Audio Players & Recorders
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
Sony ICFM350S
I would like to know how to change the MW Tuning Interval from 9Mhz to 10Mhz.
The radio is a Sony ICF - M350S
Thank you
RM
May 12, 2007 | Sony ICFM410VLIV AM/FM/Weather/TV Radio
67 people viewed this question
 Grubhead
Grubhead
