Question about Car Audio & Video
I need to bypass the factory amp in my 97 ford expedition
Im trying to install a in dash dvd player in my 97 ford expedition but i am not getting any sound what should i do?
  • sabeqmd Jan 12, 2009
    I have the same problem
The amp is in the rear panel pass side if you have the Mach sound system. There are 5 wires going into the amp and 2 going out to the sub.
Light Grn w/ Purple stripe is the 12v power (thick)
Blk w/ Grn Stripe is the grnd (thick)
Drk Grn w/ Pruple stripe is the remote (thin)
Red w/ blk stripe is sub high output +
Drk Brown with Orange is the high output -
Posted on Mar 07, 2009
Just bybass the factory amp by running the speaker wires in each door.I searched for the factory amp and gave up after 2hrs.it is easier to bypass it at the factory amp,but i could not find it.good luck to all
Posted on Feb 06, 2009
  • David Davis Sep 24, 2012
    the amp was under neath the center piece,under the radeo
    Reg. factory amp is under the radeo. but u need to remove the center to get underneth the dash right there
    Problem Solver:
  • 3 Answers
    New Friend:
Are you guys still needing to bypass the factory amp?
Posted on May 01, 2015
Does anyone no where the Factory amp is located in a 97 Ford Expedition? and how i can bypass it without a "Bypass Harness"
Posted on Oct 25, 2009
  • KermTheWorm Nov 11, 2010
    The factory amp for the door speakers is mounted vertically directly under the Climate Control ASSY under the Radio. The connectors are on the bottom of the amp. You have to take out the console (directions are here - http://www.fordforums.com/f60/97-eddie-b... ). I am still working on finding the wiring diagrams for the amp connectors.
  • budmantodd31 Jun 01, 2011
    Google bypass harness for Ford expedition. You can buy a bypass harness for around $10. Its a straight hook up and ur ready to go.
I have a 2003 eddie bauer ford expedition, when im driving, i can hear a sound like air coming from a tire under the dash on the drivers side floor area. when i tap on my break the sound goes away, what...
A vacuum leak. Look & listen for hissing noise where rubber or nylon lines come through firewall under dash near brake pedal. Also look under hood at large hose going to back of brake master cylinder, power brake booster.
Jul 01, 2010 | 2003 Ford Expedition
97 expedition - 4x4 does not engage
i have the same problem can't figured it out although when i turn the knob to AWD the light on dash just flashes. the 4x4 H and 4x4 L light on dash stays on.if u have found out anything please let me know or e mail me at bigd6923@yahoo.com Thanks Don
Jan 28, 2010 | 1997 Ford Expedition
I need wiring color code for 97 Ford Expedition
red/yellow leads from the 5amp fuse #29 and red/white leads from 5amp fuse #2. Both of these run into the instrument panel. Let me know if you need more info.
Jan 25, 2010 | 1997 Ford Expedition
Where is the DLC for the OBDII on a 97 Expedition?
its on driverside toard the center or the dash, if you look under the dash toward the center console you will seeit.a402aee.gif
Jan 16, 2010 | 1997 Ford Expedition
My 97 ford expedition sputters when I drive it
u need more high octane gasoline....97% or more
Jul 12, 2009 | 1997 Ford Expedition
97 expedition cranks,but not starting
have to have the key reprogramed. you can try the 3 step cycle. turn the key to run for 10 mins than cycle to off and back on. you have to do 3 10 mins cycle
Oct 06, 2008 | 2001 Ford Expedition
How to remove the factory installed dvd player
ONCE YOU REMOVE THE 4 RETAINING SCREWS THERE ARE 3 CLIPS THAT ATTACH TO THE HEADLINER JUST PULL STRAIGHT DOWN ON THE UNIT AND AND DISCONNECT THE WIRING HARNESS..
Aug 20, 2008 | 2005 Ford Expedition
How to install my car stereo into my 97 for expidition?
get wire harness- get indash kit - get antenna adapter(if needed).
then do it yourself. note. that is why installers exist. so that you wont have to be asking all these stupid questions.
from, worker at Best Buy
May 24, 2008 | Pioneer DEH-P2000 CD Player
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Car Audio & Video Logo
4,857 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
