Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
How do i change my security settings - Belkin (F5D8231-4) Wireless Router (F5D82314)
  • 40 Answers
The first thing you need to do is log into your router. In order to do that you need to access the IP address that is being broadcasted by your router. Generally it is 192.168.1.1. When it asks for your user name and password, you will need to input administrator and the administrator password or admin and the admin password. Then you should be able to get into your router and change the security settings. Though depending on what they are, you should be just fine unless it is unsecure, in which case you would need to log in and change that.
Posted on Nov 16, 2009
I am trying to play pokemon black with dream world but it said the acess point's security settings are not supported by Nintendo DS what do I do
Most of the time this error means that the network that you are connecting to is secured using WPA encryption. The Nintendo DS is not compatible with this type of security which is why you aren't able to connect.
There are two solutions to fix this. Either change your network security from WPA to WEP encryption (That is my recomendation) or to just disable your network security completely.(not Recomended) In order to change the security settings you would have to log on to your router from your desktop computer and change the settings from there.
For instruction on how to change your Routers security setting check your Routers users manual.
Jun 08, 2011 | Computers & Internet
Securing wireless network
By setting up WPA2 encryption you are securing your wireless network from unauthorized access.
For details on how to further secure your wireless network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 09, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I change my security settings in my dir 600
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable. Do not change wireless settings using a wireless computer.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Mar 01, 2010 | D-Link DIR-600 Router
Ip address wrong, showing 192.168.254.1
Solution Overview
This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
Printer response to security settings changes
The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
  • -A change to the Service Set Identifier (SSID) or network name.
  • -A change to the security type (none, WEP, WPA, or WPA2 personal).
  • -A change to the security network key/passphrase.
  • -A hard reset of the router followed by entry of security values that are different from the original values.
  • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
Solution: Change the printer settings first
Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
Procedure: How to change security settings via the embedded web server
If you change your AP security settings frequently, this procedure is for you.
  1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
  2. Click on Configuration.
  3. Click on Wireless.
  4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
  5. Click Submit.
Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
I want to change my security code. Right now its the same default code 12345. But dont know how to change it as i desire?
To change your security code from the default, follow these steps carefully;
  1. Press Menu
  2. From Menu, go to Settings,
  3. From Settings, scroll to Security settings
  4. From Security Settings, go to Access Codes,
  5. Press Access codes and you would see Change Change Security Code.
  6. Press Change Securty code and you would be asked to enter your old security code (which is 12345, the one your are presently using) and thereafter, you would be required to enter the new security code.
I wish you the best and don't forget to rate this.
Dec 29, 2009 | Nokia 6233 Cellular Phone
Need to change password from previously changed password
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
Brought a new laptop with wireless installed have a philips SNB5600 but have lost the security key how can i get the code
go to the wireless access point admin settings (not on your wireless adapter on your laptop). then check wireless security settings. if you see something there such as security key, that is the security key that you need to set up on your laptop. if security key is not visible, try to see if there is an option there which says unmask to show the security key, then copy it to your laptop. if all else fails, change the security key in the wireless access point and change all the wireless adapters that connect to it accordingly to the new security key you set it up.
Nov 07, 2009 | Computers & Internet
My security code and i want to unlock it
Enter the lock code instead of the security code. After then to change the security code.
  1. Go to menu and there open settings.
  2. There open security settings.
  3. There will options such as change lock code or change security code etc.
  4. If you have forgot security code then you can't change it, better change lock code as your desired password.
  5. To change first get into change lock code and enter old lock code and after that input new password and its all done.
Aug 14, 2009 | Lands Phones
Help me pleace phone code nokia 5800 Xpres musik
Go 2 ur SETTINGS->PHONE SETTINGS->SECURITY SETTINGS
->CHANGE ACCESS CODES->CHANGE SECURITY CODES.
if u hav not use ur security codes b4 this.key in 12345.after tat key in ur new security code no.
avoid ur sims card from bocking.change ur security level.use PHONE LEVEL.
i hope u can do it. ;)
Dec 24, 2008 | Nokia N73 Cellular Phone
Cannot change network security
if you change any security setting it likely has to reboot.
if the wireless won't reconnect , start with no security setting for open/no security and see how it responds.
then match the settings exact.
otherwise update the bios in the router.
Mar 04, 2008 | Linksys WRT54G Wireless-G Broadband Router...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
124 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
