Question about Akai PT61DL34 Television
There is a loud humming on my AKAI DLP PT61DL34
I had just replaced the lamp to my Akai Dlp TV & it works fine it just has a loud humming to it. It started happening about a week before the lamp went out. I figured that when i change the lamp out it might fix the problem with the humming also. Any advice on what might be the problem?
  • dannylefe Nov 16, 2009
    Thank you for you advice and now i can go on to replacing that also... Thanks..
  • 3,037 Answers
Most likely the color wheel is the problem. The color wheel is exactly what it sounds like, it is a wheel with multiple colors on it that spins at a very high RPM to produce the colors. When the bearings start to go, it starts to hum and will be very high pitched right before it breaks. Once it breaks, you will only see black and white images. It isn't that hard to replace for anyone who does general fix-it problems around the house, just make sure the tv is unplugged overnight before touching anything in it. You should be able to get a new color wheel through the manufacturer. Let me know how this works out for you. Benjamin
Posted on Nov 16, 2009
60 inch Akai DLP TV, PT61DL34 horizontal lines on the screen.
Its a DLP and the optical unit has thousands of tiny micro mirrors that cannot be adjusted.
Apr 29, 2012 | Televison & Video
My akai dlp tv stopped working
Akai is really Samsung---
Remove and inspect lamp to see if shattered inside--it is a cartridge and very easy to remove.
With it out look where the lamp faces and see if the color wheel pictured here is intact (no pieces missing etc).
Apr 16, 2012 | Akai PT46DL10 46" HDTV-Ready Television
I have a akai 61 inch dlp tv, my son turned it off went back 1 hour later tv would not come on with remote or by push button on front, checked to make sure power was in cord to back of tv, any ideas what...
I'm assuming that no lights are blinking on the front of the tv and the bulb is in god working order - it has been replaced recently. In that case the tv will have to be opened and the voltages on the power source tested, starting with the ones on the main switching transistor, followed by the ones on the output rails - a good voltmeter will have to be used. If all are there then check the voltage going to the
Jul 29, 2011 | Akai PT61DL34 Television
Dlp tv has lines across the tv its a 61 inch dlp akai tv just want to know why it has blue lines across it ...... ??? please help??
You have a bad light engine. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating!!!!
hardrocko
Apr 27, 2010 | Akai PT61DL34 Television
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Need new Jl amp
DLP LAMP SOURCE. PO BOX 503882 SAN DIEGO CA.92150
Mar 12, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Akai PT61DL34 Television Logo
105 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
