Why will only hot water go into machine? - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
It can be one of two problems. Either the solenoid valve is bad on the cold side or the screen is plugged on the cold side. Take the cold water hose off and check the screen that is located right inside off where you connect the hose to the washer. Open the valev on the hose while you have it off and make sure that water flows from the hose so you know you are getting water to the washer. After cleaning the screen reconnest the hose. If it still does not work then your valve is bad. Replace that.
Posted on Nov 16, 2009
Don't think machine is washing clothes in hot water . What could be wrong ?
1) Improper water temperature selection, 2) no hot water to machine due to: a) being valved off, b) clogged filter or strainer, c) kinked hot water supply hose, d) failed hot water solenoid valve or bad / of loose wiring connection inside the washer or 3) depleted hot water in domestic hot water tank due to previous laundry washes / bathing / etc..
May 19, 2015 | Zanussi Washing Machines
Washing machine not heating water
washing machine does not heat water? no hot water check ur water inlet valve
Feb 23, 2015 | Washing Machines
Does anyone know Why the hot water does not go into the machine when using warm water selection, hot water is in hose but not in machine ?
The hot water valve is not opening. This could be the valve or the timer. What make and model and year is it?
Sep 12, 2014 | Washing Machines
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
I have a MAYTAG legacy Series manine. That i just bought from a retailer. My machine is connected to a cold water tap. can i still get a hot water wash if i select a warm or hot cycle? Secondly,...
hello bz... there can be no hot water wash or hot cycle without hooking up a hot water supply line. Also, you must plug that hot water inlet, the correct plug is available at most hardware stores. Finally, yes it is normal for the machine to stop before draining, as the transmission shifts. If the machine is very noisy, that is not normal. To reduce that noise you could put the machine on a piece of thick carpet to deaden the noise a bit. Joe
Thanks for choosing Fixya!
Feb 25, 2011 | Maytag Legacy Series Top Load Washer
No hot water
Not quite enough information to go on here ... the machine connects to hot and cold water or cold water only? If cold only, is it designed to heat its own water?
If connected to hot water ... some newer machines are dependent on sufficient water pressure. Check pressure of hot water is adequate at the tap (and that the water is hot). Check for a blocked filter in the water inlet house at the point of connection to the rear of the machine (remove the hose to check).
Mar 05, 2010 | Washing Machines
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
Hot water not going into washing machine
hi there,
try the following, it may help:
Some washing machines allow hot water to enter only during certain cycles. Others intermittently
allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual
if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Nov 05, 2008 | Frigidaire Gallery GLWS1339EC Top Load...
Machine not filling with hot water
First check the filters in the inlet hose and hot water pressure. Sounds to me like the hot water valve is faulty. Test the w/machine on a hot water cycle, if you hear a noise and its not filling it up with water,its a faulty hot water valve. Air pressure?? change the water valve and remember it has a little rubber boot on the old water valve, transfer this to the new valve,or go into option adjustment mode and change you wash temperature settings.
Aug 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
